[Swift-devel] Re: No provider specified error
    Jonathan Monette
    jon.monette at gmail.com
    Mon Jan 24 22:29:02 CST 2011
Ok.  Will give that a try next.  Thanks.
On 1/24/11 10:27 PM, Mihael Hategan wrote:
> I'd suggest removing the<filesystem>  entry in sites.xml. And also using
> "file" as staging method, since the client and coaster service are on
> the same machine.
> On Mon, 2011-01-24 at 22:03 -0600, Jonathan Monette wrote:
>> execution.retries=0
>> sitedir.keep=true
>> status.mode=provider
>> wrapper.log.always.transfer=true
>> foreach.maxthreads=1024
>> wrapper.parameter.mode=files
>> use.provider.staging=true
>> provider.staging.pin.swiftfiles=false
>> If the last two lines are commented out my work flow runs.  Here is my
>> sites file
>> <config>
>> <pool handle="localhost">
>> <execution provider="local" />
>> <filesystem provider="local" />
>> <profile key="jobThrottle" namespace="karajan">.05</profile>
>> <profile key="SWIFT_GEN_SCRIPTS" namespace="env">1</profile>
>> <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/localhost</workdirectory>
>> </pool>
>> <pool handle="pads">
>> <execution jobmanager="local:pbs" provider="coaster" />
>> <profile key="maxtime" namespace="globus">3600</profile>
>> <profile key="internalhostname" namespace="globus">192.5.86.6</profile>
>> <profile key="workersPerNode" namespace="globus">1</profile>
>> <profile key="slots" namespace="globus">40</profile>
>> <profile key="nodeGranularity" namespace="globus">1</profile>
>> <profile key="maxNodes" namespace="globus">1</profile>
>> <profile key="queue" namespace="globus">fast</profile>
>> <profile key="jobThrottle" namespace="karajan">1</profile>
>> <profile key="initialScore" namespace="karajan">10000</profile>
>> <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
>> </pool>
>> </config>
>> On 1/24/11 9:57 PM, Mihael Hategan wrote:
>>> Not quite. Proxy is just a coaster staging method in which the coaster
>>> service acts as a network proxy between the client and the worker
>>> node(s).
>>> I do not know what causes your problem. It looks odd. Can you post your
>>> broken configuration (swift.properties and sites file)?
>>> Mihael
>>> On Mon, 2011-01-24 at 21:28 -0600, Jonathan Monette wrote:
>>>> Figured out what was wrong.  I was using some properties in my sites.xml
>>>> for provider staging per Mike's suggestion.  By commenting those lines
>>>> out my workflow began working again.  I am assuming for provider staging
>>>> to work a 'proxy' must be set up and I do not believe I have set one
>>>> up.  However I am unfamiliar with provider staging, this was a
>>>> suggestion by Mike to try next in a list of things for me to do.
>>>> On 1/24/11 7:42 PM, Jonathan Monette wrote:
>>>>> Scratch that, I do have execution provider="local" set in my
>>>>> sites.xml.  I am not sure where the problem is.  Still looking.
>>>>> On 1/24/11 7:38 PM, Jonathan Monette wrote:
>>>>>> Ok.  I went searching through some of the cog code for this error
>>>>>> when I took a close look at this line from the log file:
>>>>>> Caused by:
>>>>>> org.globus.cog.abstraction.impl.common.task.InvalidProviderException:
>>>>>> No 'proxy' provider or alias found. Available providers: [cobalt,
>>>>>> gsiftp, coaster, webdav, dcache, ssh, gt4, gt2, condor, http,
>>>>>> coaster-persistent, pbs, ftp, gsiftp-old, local, sge]
>>>>>> I am assuming that all these providers listed are the acceptable
>>>>>> entries in the sites.xml for the execution provider entry.  I notice
>>>>>> that localhost isn't an acceptable execution provider.  Was localhost
>>>>>> switched to local(which is an acceptable value) in cog-r3043?
>>>>>> On 1/23/11 10:18 PM, Jonathan Monette wrote:
>>>>>>> Mihael,
>>>>>>>      I just updated to cog-r3043 and swift-r4031.  I now get this
>>>>>>> swift error:
>>>>>>> Execution failed:
>>>>>>> [cobalt, gsiftp, coaster, webdav, dcache, ssh, gt4, gt2, condor,
>>>>>>> http, coaster-persistent, pbs, ftp, gsiftp-old, local, sge].
>>>>>>> Aliases: gt4<->   gt4.0.2, gt4.0.1, gt3.9.5, gt4.0.0; condor<->
>>>>>>> condorlocal; cobalt<->   cobaltlocal; gsiftp<->   gridftp; pbs<->
>>>>>>> pbslocal; gsiftp-old<->   gridftp-old; local<->   file;
>>>>>>> Upon inspecting the log file I got found this Java error:
>>>>>>> 2011-01-23 18:31:27,221-0600 INFO  AbstractionProperties No
>>>>>>> properties for provider proxy. Using empty properties
>>>>>>> 2011-01-23 18:31:27,227-0600 INFO  vdl:execute END_FAILURE
>>>>>>> thread=0-3 tr=mImgtbl
>>>>>>> 2011-01-23 18:31:27,234-0600 DEBUG VDL2ExecutionContext sys:throw @
>>>>>>> execute-default.k, line: 45: Exception in mImgtbl:
>>>>>>> Arguments: [proj_dir, images.tbl]
>>>>>>> Host: localhost
>>>>>>> Directory:
>>>>>>> rectified-20110123-1707-ptqrq9j5/jobs/3/mImgtbl-3krv2x4kTODO: outs
>>>>>>> Host: localhost
>>>>>>> Directory:
>>>>>>> Caused by: No 'proxy' provider or alias found. Available providers:
>>>>>>> Caused by:
>>>>>>> org.globus.cog.abstraction.impl.common.task.InvalidProviderException: No
>>>>>>> coaster-persistent, pbs, ftp, gsiftp-old, local, sge]. Aliases: gt4
>>>>>>> <->   gt4.0.2, gt4.0.1, gt3.9.5, gt4.0.0; condor<->   condorlocal;
>>>>>>> cobalt<->   cobaltlocal; gsiftp<->   gridftp; pbs<->   pbslocal;
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.functions.KException.function(KException.java:29)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:27)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:32)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:340)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:173)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:181)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:309)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:50)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:26)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:238)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:289)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:402)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:343)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:230)
>>>>>>>       at
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:44)
>>>>>>>       at
>>>>>>> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
>>>>>>>       at
>>>>>>> edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
>>>>>>>       at
>>>>>>> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
>>>>>>>       at
>>>>>>> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
>>>>>>>       at java.lang.Thread.run(Thread.java:662)
>>>>>>> Caused by:
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:36)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:42)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:153)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.grid.GridExec.taskFailed(GridExec.java:373)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode.statusChanged(AbstractGridNode.java:276)
>>>>>>>       at
>>>>>>> org.griphyn.vdl.karajan.lib.Execute.statusChanged(Execute.java:127)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.scheduler.AbstractScheduler.fireJobStatusChangeEvent(AbstractScheduler.java:168)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.scheduler.LateBindingScheduler.statusChanged(LateBindingScheduler.java:675)
>>>>>>>       at
>>>>>>> org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler.statusChanged(WeightedHostScoreScheduler.java:422)
>>>>>>>       at
>>>>>>> org.griphyn.vdl.karajan.VDSAdaptiveScheduler.statusChanged(VDSAdaptiveScheduler.java:410)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.common.task.TaskImpl.notifyListeners(TaskImpl.java:240)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:228)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.common.AbstractDelegatedTaskHandler.failTask(AbstractDelegatedTaskHandler.java:54)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.run(JobSubmissionTaskHandler.java:220)
>>>>>>>       at
>>>>>>> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>>>>>>>       at
>>>>>>> java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>>>>>>>       at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>>>>>>>       at
>>>>>>> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>>>>>>>       at
>>>>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>>>>>>>       ... 1 more
>>>>>>> Caused by:
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.common.AbstractionProperties.getProperties(AbstractionProperties.java:138)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.common.AbstractionFactory.newObject(AbstractionFactory.java:136)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.common.AbstractionFactory.newFileResource(AbstractionFactory.java:112)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.copy(JobSubmissionTaskHandler.java:293)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.stage(JobSubmissionTaskHandler.java:272)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.stageIn(JobSubmissionTaskHandler.java:283)
>>>>>>>       at
>>>>>>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.run(JobSubmissionTaskHandler.java:159)
>>>>>>>       ... 6 more
>>>>>>> 2011-01-23 18:31:27,274-0600 INFO  ExecutionContext Detailed exception:
>>>>>>> Host: localhost
>>>>>>> Directory:
>>>>>>> Caused by:
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>> Caused by:
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       ... 1 more
>>>>>>> Caused by:
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       at
>>>>>>>       ... 6 more
>>>>>>> I am running on PADS and here is my sites.xml file:
>>>>>>> <config>
>>>>>>> </pool>
>>>>>>> </pool>
>>>>>>> </config>
>>>>>>> Has anyone else seen this error or Mihael have you witnessed this?
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
