[Swift-devel] Re: No provider specified error
Jonathan Monette jon.monette at gmail.com
Mon Jan 24 19:42:16 CST 2011
Scratch that, I do have execution provider="local" set in my sites.xml.
I am not sure where the problem is.  Still looking.
On 1/24/11 7:38 PM, Jonathan Monette wrote:
> Ok.  I went searching through some of the cog code for this error when
> I took a close look at this line from the log file:
> Caused by:
> org.globus.cog.abstraction.impl.common.task.InvalidProviderException:
> No 'proxy' provider or alias found. Available providers: [cobalt,
> gsiftp, coaster, webdav, dcache, ssh, gt4, gt2, condor, http,
> coaster-persistent, pbs, ftp, gsiftp-old, local, sge]
> I am assuming that all these providers listed are the acceptable
> entries in the sites.xml for the execution provider entry.  I notice
> that localhost isn't an acceptable execution provider.  Was localhost
> switched to local(which is an acceptable value) in cog-r3043?
> On 1/23/11 10:18 PM, Jonathan Monette wrote:
>> Mihael,
>>    I just updated to cog-r3043 and swift-r4031.  I now get this swift
>> error:
>> Execution failed:
>> coaster-persistent, pbs, ftp, gsiftp-old, local, sge]. Aliases: gt4
>> <-> gt4.0.2, gt4.0.1, gt3.9.5, gt4.0.0; condor <-> condorlocal;
>> cobalt <-> cobaltlocal; gsiftp <-> gridftp; pbs <-> pbslocal;
>> gsiftp-old <-> gridftp-old; local <-> file;
>> Upon inspecting the log file I got found this Java error:
>> 2011-01-23 18:31:27,221-0600 INFO  AbstractionProperties No
>> properties for provider proxy. Using empty properties
>> 2011-01-23 18:31:27,227-0600 INFO  vdl:execute END_FAILURE thread=0-3
>> tr=mImgtbl
>> 2011-01-23 18:31:27,234-0600 DEBUG VDL2ExecutionContext sys:throw @
>> execute-default.k, line: 45: Exception in mImgtbl:
>> Arguments: [proj_dir, images.tbl]
>> Host: localhost
>> Directory:
>> rectified-20110123-1707-ptqrq9j5/jobs/3/mImgtbl-3krv2x4kTODO: outs
>> Host: localhost
>> Directory:
>> Caused by: No 'proxy' provider or alias found. Available providers:
>> [cobalt, gsiftp, coaster, webdav, dcache, ssh, gt4, gt2, condor,
>> http, coaster-persistent, pbs, ftp, gsiftp-old, local, sge]. Aliases:
>> gt4 <-> gt4.0.2, gt4.0.1, gt3.9.5, gt4.0.0; condor <-> condorlocal;
>> Caused by:
>>     at
>> org.globus.cog.karajan.workflow.nodes.functions.KException.function(KException.java:29)
>>     at
>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:27)
>>     at
>> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
>>     at
>> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:32)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:340)
>>     at
>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:173)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:181)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:309)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>>     at
>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
>>     at
>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:50)
>>     at
>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:26)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:238)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:289)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:402)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:343)
>>     at
>> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:230)
>>     at
>>     at
>> org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:44)
>>     at
>> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
>>     at
>> edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
>>     at
>> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
>>     at
>> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
>>     at java.lang.Thread.run(Thread.java:662)
>> Caused by:
>>     at
>> org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:36)
>>     at
>> org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:42)
>>     at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:153)
>>     at
>> org.globus.cog.karajan.workflow.nodes.grid.GridExec.taskFailed(GridExec.java:373)
>>     at
>> org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode.statusChanged(AbstractGridNode.java:276)
>>     at
>> org.griphyn.vdl.karajan.lib.Execute.statusChanged(Execute.java:127)
>>     at
>> org.globus.cog.karajan.scheduler.AbstractScheduler.fireJobStatusChangeEvent(AbstractScheduler.java:168)
>>     at
>> org.globus.cog.karajan.scheduler.LateBindingScheduler.statusChanged(LateBindingScheduler.java:675)
>>     at
>> org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler.statusChanged(WeightedHostScoreScheduler.java:422)
>>     at
>> org.griphyn.vdl.karajan.VDSAdaptiveScheduler.statusChanged(VDSAdaptiveScheduler.java:410)
>>     at
>> org.globus.cog.abstraction.impl.common.task.TaskImpl.notifyListeners(TaskImpl.java:240)
>>     at
>> org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:228)
>>     at
>> org.globus.cog.abstraction.impl.common.AbstractDelegatedTaskHandler.failTask(AbstractDelegatedTaskHandler.java:54)
>>     at
>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.run(JobSubmissionTaskHandler.java:220)
>>     at
>> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>>     at
>> java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>>     at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>>     at
>> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>>     at
>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>>     ... 1 more
>> Caused by:
>>     at
>> org.globus.cog.abstraction.impl.common.AbstractionProperties.getProperties(AbstractionProperties.java:138)
>>     at
>> org.globus.cog.abstraction.impl.common.AbstractionFactory.newObject(AbstractionFactory.java:136)
>>     at
>> org.globus.cog.abstraction.impl.common.AbstractionFactory.newFileResource(AbstractionFactory.java:112)
>>     at
>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.copy(JobSubmissionTaskHandler.java:293)
>>     at
>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.stage(JobSubmissionTaskHandler.java:272)
>>     at
>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.stageIn(JobSubmissionTaskHandler.java:283)
>>     at
>> org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.run(JobSubmissionTaskHandler.java:159)
>>     ... 6 more
>> 2011-01-23 18:31:27,274-0600 INFO  ExecutionContext Detailed exception:
>> Host: localhost
>> Directory:
>> Caused by:
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>> Caused by:
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     ... 1 more
>> Caused by:
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     ... 6 more
>> I am running on PADS and here is my sites.xml file:
>> <config>
>> <pool handle="localhost">
>> <execution provider="local" />
>> <filesystem provider="local" />
>> <profile key="jobThrottle" namespace="karajan">.05</profile>
>> <profile key="SWIFT_GEN_SCRIPTS" namespace="env">1</profile>
>> <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/localhost</workdirectory>
>> </pool>
>> <pool handle="pads">
>> <execution jobmanager="local:pbs" provider="coaster" />
>> <profile key="maxtime" namespace="globus">3600</profile>
>> <profile key="internalhostname" namespace="globus">192.5.86.6</profile>
>> <profile key="workersPerNode" namespace="globus">1</profile>
>> <profile key="slots" namespace="globus">40</profile>
>> <profile key="nodeGranularity" namespace="globus">1</profile>
>> <profile key="maxNodes" namespace="globus">1</profile>
>> <profile key="queue" namespace="globus">fast</profile>
>> <profile key="jobThrottle" namespace="karajan">1</profile>
>> <profile key="initialScore" namespace="karajan">10000</profile>
>> <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
>> </pool>
>> </config>
>> Has anyone else seen this error or Mihael have you witnessed this?
