[Swift-devel] Swift compile issues on IBI cluster
Tim Armstrong tim.g.armstrong at gmail.com
Sat Jan 22 12:08:03 CST 2011
Thanks, that appears to fix it.  It is a very strange issue.  It almost
looks like the output from the .swift -> .xml stage isn't written to the
.xml file before the next stage tries to read.  Either that or there is a
silent failure somewhere in that stage
On Sat, Jan 22, 2011 at 7:09 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Mihael commented on this problem in this post Nov 3:
> http://mail.ci.uchicago.edu/mailman/private/swift-devel/2010-November/006990.html
> (likely SAX incompatibility problem with that particular Java version)
> Tim, I forgot to mention: on IBI you need to use the Java in my home dir
> (or any recent Java).  The particular SUn java thats the default there has
> some weird issue in xml parsing that causes this failure.
> - Mike
> Hi,
>   I'm trying to get a Swift script running on the IBI cluster but have been
> running into some issues.  I'm using a recent development version 3029.
> Running the script fails at the compile stage.
> Strangely, this script compiles without issue using exactly the same swift
> on other machines.
> Even more strangely, it looks like the swift ->  intermediate xml step
> completes without any exceptions being thrown, but when I look at the xml
> file it contains precisely zero bytes.  It appears that this is what
> actually causes the karajan parser to crash.
> What would cause the first compile step to complete without causing an
> exception but not produce any output?  Do we maybe have a buffering issue?
> Any suggestions for how I might solve this?
> The log contents are:
> 2011-01-21 16:43:13,448-0600 DEBUG Loader Max heap: 238616576
> 2011-01-21 16:43:13,449-0600 INFO  Loader rserver.swift: source file is
> new. Recompiling.
> 2011-01-21 16:43:13,919-0600 DEBUG Loader Detailed exception:
> org.griphyn.vdl.karajan.CompilationException: Unable to parse intermediate
> XML
>         at org.griphyn.vdl.engine.Karajan.compile(Karajan.java:98)
>         at org.griphyn.vdl.karajan.Loader.compile(Loader.java:300)
>         at org.griphyn.vdl.karajan.Loader.main(Loader.java:145)
> Caused by: org.apache.xmlbeans.XmlException:
> /tmp/tga/SwiftR/swift.local.2306/rserver.xml:2:1: error: Unexpected end of
> file after null
>         at
> org.apache.xmlbeans.impl.store.Locale$SaxLoader.load(Locale.java:3467)
>         at
> org.apache.xmlbeans.impl.store.Locale.parseToXmlObject(Locale.java:1270)
>         at
> org.apache.xmlbeans.impl.store.Locale.parseToXmlObject(Locale.java:1257)
>         at
> org.apache.xmlbeans.impl.schema.SchemaTypeLoaderBase.parse(SchemaTypeLoaderBase.java:345)
>         at
> org.apache.xmlbeans.impl.schema.SchemaTypeLoaderBase.parse(SchemaTypeLoaderBase.java:252)
>         at
> org.globus.swift.language.ProgramDocument$Factory.parse(ProgramDocument.java:499)
>         at org.griphyn.vdl.engine.Karajan.parseProgramXML(Karajan.java:122)
>         at org.griphyn.vdl.engine.Karajan.compile(Karajan.java:96)
>         ... 2 more
> Caused by: org.xml.sax.SAXParseException: Unexpected end of file after null
>         at
> org.apache.xmlbeans.impl.piccolo.xml.Piccolo.reportFatalError(Piccolo.java:1038)
>         at
> org.apache.xmlbeans.impl.piccolo.xml.Piccolo.parse(Piccolo.java:723)
>         at
> org.apache.xmlbeans.impl.store.Locale$SaxLoader.load(Locale.java:3435)
>         ... 9 more
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110122/509d1b4a/attachment.html>
