[Swift-devel] Swift compile issues on IBI cluster
Tim Armstrong tim.g.armstrong at gmail.com
Fri Jan 21 22:20:40 CST 2011
Its Sun Java 6  so I assumed that would be fine.
The exact version is 1.6.0_07.
- Tim
On Fri, Jan 21, 2011 at 9:07 PM, Allan Espinosa
<aespinosa at cs.uchicago.edu>wrote:
> Hi Tim,
> What's the version of java on IBI that the Swift runtime uses?
> -Allan
> 2011/1/21 Tim Armstrong <tim.g.armstrong at gmail.com>:
> > Hi,
> >   I'm trying to get a Swift script running on the IBI cluster but have
> been
> > running into some issues.  I'm using a recent development version 3029.
> > Running the script fails at the compile stage.
> > Strangely, this script compiles without issue using exactly the same
> swift
> > on other machines.
> > Even more strangely, it looks like the swift ->  intermediate xml step
> > completes without any exceptions being thrown, but when I look at the xml
> > file it contains precisely zero bytes.  It appears that this is what
> > actually causes the karajan parser to crash.
> > What would cause the first compile step to complete without causing an
> > exception but not produce any output?  Do we maybe have a buffering
> issue?
> > Any suggestions for how I might solve this?
> > The log contents are:
> > 2011-01-21 16:43:13,448-0600 DEBUG Loader Max heap: 238616576
> > 2011-01-21 16:43:13,449-0600 INFO  Loader rserver.swift: source file is
> new.
> > Recompiling.
> > 2011-01-21 16:43:13,919-0600 DEBUG Loader Detailed exception:
> > org.griphyn.vdl.karajan.CompilationException: Unable to parse
> intermediate
> > XML
> >         at org.griphyn.vdl.engine.Karajan.compile(Karajan.java:98)
> >         at org.griphyn.vdl.karajan.Loader.compile(Loader.java:300)
> >         at org.griphyn.vdl.karajan.Loader.main(Loader.java:145)
> > Caused by: org.apache.xmlbeans.XmlException:
> > /tmp/tga/SwiftR/swift.local.2306/rserver.xml:2:1: error: Unexpected end
> of
> > file after null
> >         at
> > org.apache.xmlbeans.impl.store.Locale$SaxLoader.load(Locale.java:3467)
> >         at
> > org.apache.xmlbeans.impl.store.Locale.parseToXmlObject(Locale.java:1270)
> >         at
> > org.apache.xmlbeans.impl.store.Locale.parseToXmlObject(Locale.java:1257)
> >         at
> org.apache.xmlbeans.impl.schema.SchemaTypeLoaderBase.parse(SchemaTypeLoaderBase.java:345)
> >         at
> org.apache.xmlbeans.impl.schema.SchemaTypeLoaderBase.parse(SchemaTypeLoaderBase.java:252)
> >         at
> org.globus.swift.language.ProgramDocument$Factory.parse(ProgramDocument.java:499)
> >         at
> org.griphyn.vdl.engine.Karajan.parseProgramXML(Karajan.java:122)
> >         at org.griphyn.vdl.engine.Karajan.compile(Karajan.java:96)
> >         ... 2 more
> > Caused by: org.xml.sax.SAXParseException: Unexpected end of file after
> null
> >         at
> org.apache.xmlbeans.impl.piccolo.xml.Piccolo.reportFatalError(Piccolo.java:1038)
> >         at
> > org.apache.xmlbeans.impl.piccolo.xml.Piccolo.parse(Piccolo.java:723)
> >         at
> > org.apache.xmlbeans.impl.store.Locale$SaxLoader.load(Locale.java:3435)
> >         ... 9 more
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110121/ba7064cf/attachment.html>
