[Swift-devel] Re: Did usage tracking fall off of 0.92?
Michael Wilde wilde at mcs.anl.gov
Thu Jan 13 11:33:57 CST 2011
OK, I'll need to double check my 0.92 build on engage-submit.  This is the second case of unexpected results, so maybe I goofed in my checkouts.
- Mike
----- Original Message -----
> Mike,
> I checked the swift shell script for 0.92 and everything looks good.
> I'm not sure what changed in terms of the udp message, but I ran 0.92
> from my machine and verified that it was recorded in the database.
> David
> On Thu, Jan 13, 2011 at 12:55 AM, Michael Wilde <wilde at mcs.anl.gov>
> wrote:
> > David,
> > I suspect that 0.92 may have lost your usage tracking mods to the
> > swift command. Can you check?
> > I say this because I noticed that on engage-submit, the older
> > ~Dec-15 trunk I was using gives the (expected) complaint that
> > /dev/udp is not found, while 0.92 does not complain. (Or has that
> > message just been more cleanly suppressed, or a work-around added
> > for the missing /dev/udp?)
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
Michael Wilde
