[Swift-devel] Problem with 0.92 sending jobs to OSG via Condor-G
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Jan 13 08:17:26 CST 2011
----- Original Message -----
> > I need to check what local mods I had applied, but I think its more
> > likely that some Condor submit file quoting fix fell off in 0.92
> > integration.
> Yeah. A svn diff > somefile would help.
Hmmm. So far svn diffs show no changes within provider-condor, neither between trunk and 0.92 branch nor within my working copies of those two on engage-submit, which seem to behave differently regarding Condor quoting.
Could the change(s) that were made a long time ago to fix Condor quoting be in a different module than provider-condor? If so, whats a likely place to look?
I'll check vdl-int.k next.
- Mike
> > So Marc, sorry - this release is not usable for you yet.
> > - Mike
> > > Im trying my first tests of 0.92 on engage-submit, sending 100
> > > trivial
> > > cat jobs to 10 OSG sites.
> > > My jobs seem to be all dying with the error "Found illegal
> > > unescaped
> > > double-quote" (see below).
> > > Has anyone successfully run a Condor-G job on OSG with 0.92?
> > > I'll dig deeper and try the same test with the older version of
> > > trunk
> > > that Marc has been using here with better success. Will also try a
> > > single job run and capture a simpler log and the condor-g submit
> > > file.
> > > Allan, have you tried 0.92 against COndor-G? If not, could you?
> > > Sarah, we should add some Condor-G-to-GT2 testing to 0.92
> > > validation I
> > > think.
> > > - Mike
> > > Caused by:
> > > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > > Cannot submit job: Could not submit job (condor_submit reported an
> > > exit code of 1). Submitting job(s)
> > > Found illegal unescaped double-quote: "" -e /bin/cat -out
> > > outdir/f.0065.out -err stderr.txt -i -d outdir -if data.txt -of
> > > outdir/f.0065.out -k "" -cdmfile "" -status file -a data.txtThe
> > > full
> > > arguments you specified were:
> > > /osg/data/engage/tmp/osg.hpc.ufl.edu/catsn-20110113-0025-vv4p4up3/shared/_swiftwrap
> > > cat-ajxnee4k -jobdir a -scratch "" -e /bin/cat -out
> > > outdir/f.0065.out
> > > -err stderr.txt -i -d outdir -if data.txt -of outdir/f.0065.out -k
> > > Script is:
> > > e$ cat catsn.swift
> > > type file;
> > > app (file o) cat (file i)
> > > cat @i stdout=@o;
> > > file out[]<simple_mapper; location="outdir",
> > > prefix="f.",suffix=".out">;
> > > foreach j in [1:@toint(@arg("n","1"))] {
> > > file data<"data.txt">;
> > > out[j] = cat(data);
> > > Michael Wilde
> > > Computation Institute, University of Chicago
> > > Mathematics and Computer Science Division
> > > Argonne National Laboratory
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
