[Swift-devel] running nightly.sh on pads
    David Kelly
    dk0966 at cs.ship.edu
    Tue Jan 11 12:57:54 CST 2011
When testing with ssh on the mcs machines, I noticed that if the URL
used in sites.xml doesn't match the machine name exactly in
~/.ssh/auth.defaults, a window would pop up via X windows and ask me
for credentials. I'm guessing this might be the "CredentialsDialog"
mentioned in the log?
Here is an example of how I have mine set up on mcs:
.ssh/auth.defaults:
vanquish.mcs.anl.gov.type=key
vanquish.mcs.anl.gov.username=davidk
vanquish.mcs.anl.gov.key=/home/davidk/.ssh/id_rsa
vanquish.mcs.anl.gov.passphrase=my secret phrase is here
Then the url field in sites.xml is also "vanquish.mcs.anl.gov" (if I
just use "vanquish" here, even though it's the same machine it doesn't
work and I get a popup)
On Tue, Jan 11, 2011 at 1:40 PM, Sarah Kenny <skenny at uchicago.edu> wrote:
> so i tried again changing the timeout from 500 to 900 and got a slightly
> different error in the log.
> all the files are here:
> http://www.ci.uchicago.edu/~skenny/swift_tests/run-2011-01-11/tests-2011-01-11.html
> thought i would go ahead and post to the list in case we wanted to look at
> it during the meeting.
> ~sk
> On Mon, Jan 10, 2011 at 4:59 PM, Justin M Wozniak <wozniak at mcs.anl.gov>
> wrote:
>> Hopefully that will do it- the default timeout is only 30 seconds.
>> I recommend running with -a to skip the ant build, and -p to skip
>> something else that is in there.
>> I will also take a look at why you might be getting the error messages you
>> are and try to clean some of that up.
>>        Justin
>> On Mon, 10 Jan 2011, David Kelly wrote:
>>> Maybe try increasing the time in the .timeout file? I usually see
>>> something
>>> similar when the job exceeds the timeout value
>>> On Jan 10, 2011 6:17 PM, "Sarah Kenny" <skenny at uchicago.edu> wrote:
>>>> so, i'm trying to get nightly.sh to run on pads with coasters and i'm
>>>> not
>>>> quite sure where this is falling apart. so far the only thing i've
>>>> edited
>>> is
>>>> providers/ssh-pbs-coasters/sites.template.xml (allowing it to take the
>>>> PROJECT and QUEUE variables). from what i can tell the sites.xml file
>>>> does
>>>> get generated correctly but then according to the test output it times
>>>> out
>>>> during submission:
>>>> [skenny at login1 tests]$ ./nightly.sh -c -g -s groups/group-ssh.sh
>>>> RUNNING_IN:
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/run-2011-01-10
>>>> HTML_OUTPUT:
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/run-2011-01-10/tests-2011-01-10.html
>>>> which: no ifconfig in
>>> (/ci/projects/cnari/apps/freesurfer64/bin:/ci/projects/cnari/apps/freesurfer64/fsfast/bin:/ci/projects/cnari/apps/freesurfer64/mni/bin:/ci/projects/cnari/usr/bin:/ci/projects/cnari/apps/afni:/ci/projects/cnari/apps/swift/bin:/soft/java-1.6.0_11-sun-r1/bin:/soft/java-1.6.0_11-sun-r1/jre/bin:/software/common/gx-map-0.5.3.3-r1/bin:/soft/apache-ant-1.7.1-r1/bin:/soft/condor-7.0.5-r1/bin:/soft/globus-4.2.1-r2/bin:/soft/globus-4.2.1-r2/sbin:/usr/kerberos/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/software/common/softenv-1.6.0-r1/bin:/home/skenny/bin/linux-rhel5-x86_64:/home/skenny/bin:/soft/maui-3.2.6p21-r1/bin:/soft/maui-3.2.6p21-r1/sbin:/soft/openmpi-1.4.2-gcc4.1-r1/bin)
>>>> GROUPLISTFILE: groups/group-ssh.sh
>>>> Prolog: Build
>>>> Executing (part 1)
>>>> Executing (part 2)
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift
>>>> 14815 pts/27 00:00:00 nightly.sh
>>>> monitor(1): killing test process...
>>>> touch: cannot touch `killed_test': Stale NFS file handle
>>>> monitor(1): killed process_exec (TERM)
>>>> process_exec_trap()
>>>> killing all swifts...
>>>> ++ echo 13685
>>>> 13685
>>>> ++ ps -f
>>>> UID PID PPID C STIME TTY TIME CMD
>>>> skenny 14815 1 0 15:49 pts/27 00:00:00 /bin/bash ./nightly.sh -c -g
>>>> skenny 14816 1 0 15:49 pts/27 00:00:00 /bin/bash ./nightly.sh -c -g
>>>> skenny 14879 1 0 15:49 pts/27 00:00:04 java -Xmx2048M
>>> -Djava.endorsed.dirs=/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/
>>>> skenny 15473 23767 0 15:55 pts/27 00:00:00 /bin/bash ./nightly.sh -c -g
>>>> skenny 15503 15473 7 15:55 pts/27 00:00:08
>>>> /soft/java-1.6.0_11-sun-r1/jre/bin/java -classpath
>>>> /soft/apache-ant-1.7.1-r1/lib/ant-launcher.jar
>>>> -Dant.home=/soft/apache-ant-1.7.1-r1 -Dant.
>>>> skenny 15890 14815 0 15:57 pts/27 00:00:00 ps -f
>>>> skenny 23767 23760 0 13:53 pts/27 00:00:00 -bash
>>>> ./nightly.sh: line 588: 14819 Killed "$@" > $OUTPUT 2>&1
>>>> +++ ps -f
>>>> +++ grep '.*java'
>>>> +++ grep -v grep
>>>> ++ kill_this skenny 14879 1 0 15:49 pts/27 00:00:04 java -Xmx2048M
>>> -Djava.endorsed.dirs=/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/endorsed
>>>> -DUID=1195 -DGLOBUS_TCP_PORT_RANGE=50000,51000 -DGLOBUS_HOSTNAME=
>>> login1.pads.ci.uchicago.edu-DCOG_INSTALL_PATH=/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/..
>>> -Dswift.home=/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/..
>>>> -Djava.security.egd=file:///dev/urandom -classpath
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../etc:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../libexec:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/addressing-1.0.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/antlr-2.7.5.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/axis.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/axis-url.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/backport-util-concurrent.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/coaster-bootstrap.jar:/ci/projects/cnari/soft/swift_latest
>> /cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-abstraction-common-2.4.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-axis.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-grapheditor-0.47.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-jglobus-1.7.0.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-karajan-0.36-dev.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-clref-gt4_0_0.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-coaster-0.3.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provi
>> der-dcache-0.1.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-gt2-2.4.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-local-2.2.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-localscheduler-0.4.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-ssh-2.4.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-provider-webdav-2.1.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-resources-1.0.jar:/ci/projects/cnari/soft/swift_latest/cog/mo
>> dules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-swift-svn.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-trap-1.0.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-url.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/cog-util-0.92.jar:/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/../lib/commonj.jar:/ci/projects/cnari/soft/swift_latest/cog/mo
>>>> -Dant.library.dir=/soft/apache-ant-1.7.1-r1/lib
>>>> org.apache.tools.ant.launch.Launcher -cp :./ -quiet dist
>>>> ++ '[' -n 14879 ']'
>>>> ++ /bin/kill -KILL 14879
>>>> ++ set +x
>>>> Executing Package (part 3)
>>>> Executing Package (part 4)
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/lib
>>>> Executing Package (part 5)
>>>> Executing Package (part 6)
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/bin/swift
>>>> Part 1: SSH with PBS and Coasters Configuration Test
>>>> Using:
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/tests/providers/ssh-pbs-coasters/sites.template.xml
>>>> Using:
>>> /ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/tests/providers/ssh-pbs-coasters/tc.template.data
>>> `/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/dist/swift-svn/etc/swift.properties'
>>>> -> `./swift.properties'
>>> `/ci/projects/cnari/soft/swift_latest/cog/modules/swift/tests/cog/modules/swift/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.swift'
>>>> -> `./001-catsn-ssh-pbs-coasters.swift'
>>>> Executing
>>>> (part 1)
>>>> 16623 pts/27 00:00:00 nightly.sh
>>>> process_exec_trap()
>>>> ++ echo 15473
>>>> 15473
>>>> ++ ps -f
>>>> skenny 16623 15473 0 15:58 pts/27 00:00:00 /bin/bash ./nightly.sh -c -g
>>>> skenny 16624 15473 0 15:58 pts/27 00:00:00 /bin/bash ./nightly.sh -c -g
>>>> skenny 16687 1 0 15:58 pts/27 00:00:04 java -Xmx2048M
>>>> skenny 17414 16623 0 16:06 pts/27 00:00:00 ps -f
>>>> ./nightly.sh: line 588: 16627 Killed "$@" > $OUTPUT 2>&1
>>>> +++ ps -f
>>>> +++ grep '.*java'
>>>> +++ grep -v grep
>>>> ++ kill_this skenny 16687 1 0 15:58 pts/27 00:00:04 java -Xmx2048M
>>>> ++ '[' -n 16687 ']'
>>>> ++ /bin/kill -KILL 16687
>>>> ++ set +x
>>>> kill 16624: No such process
>>>> TOOK: 500
>>>> FAILED
>>>> Swift svn swift-r3921 (swift modified locally) cog-r3013
>>>> RunID: 20110110-1558-ojtlnxfb
>>>> Progress:
>>>> Progress: Selecting site:9 Initializing site shared directory:1
>>>> nightly.sh: monitor(1): killed: exceeded 500 seconds
>>>> FAILED
>>>> ++ seq --format %04.f 1 1 10
>>>> + for count in '`seq --format "%04.f" 1 1 10`'
>>>> + '[' -f catsn.0001.out ']'
>>>> + exit 1
>>>> i'm running this directly on the pads login and seeing this in the swift
>>>> log:
>>>> 2011-01-10 16:33:18,539-0600 INFO TransportProtocolCommon The Transport
>>>> Protocol thread
>>>> failed
>>>> java.io.IOException: The socket is
>>>> EOF
>>>> at
>>> com.sshtools.j2ssh.transport.TransportProtocolInputStream.readBufferedData(TransportProtocolInputStream.java:183)
>>>> at
>>> com.sshtools.j2ssh.transport.TransportProtocolInputStream.readMessage(TransportProtocolInputStream.java:226)
>>>> at
>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.processMessages(TransportProtocolCommon.java:1440)
>>>> at
>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.startBinaryPacketProtocol(TransportProtocolCommon.java:1034)
>>>> at
>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.run(TransportProtocolCommon.java:393)
>>>> at
>>>> java.lang.Thread.run(Thread.java:619)
>>>> you can view the test output here:
>>> http://www.ci.uchicago.edu/~skenny/swift_tests/run-2011-01-10/tests-2011-01-10.html
>>>> anyway, thought i'd post this in case there's something that might jump
>>> out
>>>> at any of you that i can tweak...
>>>> ~sk
>> Justin M Wozniak
