[Swift-devel] Re: Swift on Eureka
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jan 11 10:49:12 CST 2011
Sheri, All,
I have built  Swift on Fusion (using the 0.92 branches of swift and cog)
To use:
PATH=/home/wilde/swift/rev/0.92/bin:$PATH
swift -etc
The source was built from /home/wilde/swift/src/0.92 on fusion
I have yet to test, but Sheri this should help you get started.
Please bear with us if the going starts out rough here.
We will also work on making Swift run on Eureka.
Sample (but untested) config files to use on PBS here are at:
  /home/wilde/swift/lab/{pbs.xml,tc,cf}
Please join and send all problems to swift-user:
  http://www.ci.uchicago.edu/swift/support/index.php
Im hoping that Sarah and David will soon have logins on Fusion and can help certify this release on that system.
Mike
----- Original Message -----
> No, we'll either need to build it for you or you can try to build it
> yourself.
> Sarah or David, can you do a build and sanity test of Swift on Fusion
> today?
> (If not, I will do this later today...)
> We should get this installed as a softenv package on Fusion, PADS, and
> MCS machines.
> Thanks,
> Mike
> > Is swift already installed on fussion?
> > -Sheri
> > Robert Jacob wrote:
> > > Lets use Fusion.
> > > Rob
> > > On 1/8/11 4:40 PM, Michael Wilde wrote:
> > >> Thanks, Justin. cc'ing back to the list, Rob, and Sheri.
> > >> Sheri, maybe you can run on PADS or Fusion till this is fixed?
> > >> - Mike
> > >>> Hello
> > >>> Right, Swift does not currently run on Eureka due to the
> > >>> following
> > >>> bug in Cobalt:
> > >>> http://trac.mcs.anl.gov/projects/cobalt/ticket/462
> > >>> I got about half of a work-around for this done...
> > >>> Justin
> > >>> On Fri, 7 Jan 2011, Michael Wilde wrote:
> > >>>> Hi Rob and Sheri,
> > >>>> I don't know the status of Swift on Eureka, but Im eager to see
> > >>>> it
> > >>>> running there, so we'll make sure it works.
> > >>>> A long while back I tried Swift there, and at the time we had a
> > >>>> minor
> > >>>> bug in the Cobalt provider. Justin may have fixed that recently
> > >>>> on
> > >>>> the
> > >>>> BG/P's. So Im hoping it either works or has only some
> > >>>> readily-fixable
> > >>>> issues in the way.
> > >>>> We'll try it and get back to you.
> > >>>> In the mean time, Sheri, you might want to try a simple
> > >>>> hello-world
> > >>>> test
> > >>>> on Eureka, and see if you can progress to replicating what John
> > >>>> Dennis
> > >>>> had done so far.
> > >>>> Its best to send any errors you get to the swift-user list
> > >>>> (which
> > >>>> you
> > >>>> should join) so that everyone on the Swift team is aware f any
> > >>>> issues
> > >>>> you encounter and can offer help.
> > >>>> You should meet with Justin at Argonne (3rd floor, 240) who can
> > >>>> serve as
> > >>>> your Swift mentor.
> > >>>> Sarah, David - lets add Eureka to the test matrix for release
> > >>>> 0.92.
> > >>>> Cobalt is very very close to PBS's interface, but there is a
> > >>>> separate
> > >>>> Swift execution provider that handles the differences.
> > >>>> Regards,
> > >>>> Mike
> > >>>>> Hi Mike,
> > >>>>> Sheri is going to take over some of the development work John
> > >>>>> Dennis
> > >>>>> was
> > >>>>> doing on using swift with the AMWG diag package.
> > >>>>> Our platform is Eureka. Is there a development version of
> > >>>>> Swift
> > >>>>> installed there?
> > >>>>> Rob
> > >>> Justin M Wozniak
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Michael Wilde
