[Swift-devel] Testing for new releases
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Jan  6 22:51:54 CST 2011
No, but they could/should be.  I think we originally meant to go from say pads login to bridled and communicado.
But going from mcs login to crush etc (x10) would be good to, or even better. Its up to you and Sarah; try something easy first, then increase the test intensity and diversity.
For the "bag of workstation" tests your scripts might have to deal with issues of getting the ssh environment set up reasonably for automation.
Note that you can only reach the 10x MCS servers from login.mcs, not directly from outside.  BUt you can get around this either by running the test form bridled to mcs, or by setting up an SSH master channel.
- Mike
----- Original Message -----
> In the configuration matrix, an entry exists for "CI machines." Are
> these the thwomp, stomp, crush, sneezy, grumpy, and doc machines
> @mcs.anl.gov?
> Thanks,
> David
> On Tue, Jan 4, 2011 at 9:00 PM, Sarah Kenny <skenny at uchicago.edu>
> wrote:
> > trying to make a matrix out of the matrix...first pass feel free to
> > correct
> > http://www.ci.uchicago.edu/wiki/bin/view/SWFT/ReleasePlans#site_specific_tests
> > On Tue, Jan 4, 2011 at 2:29 PM, Justin M Wozniak
> > <wozniak at mcs.anl.gov>
> > wrote:
> >> On Tue, 4 Jan 2011, David Kelly wrote:
> >>> During today's conference call, a matrix of configurations was
> >>> mentioned which contained a preliminary list of what needed to be
> >>> supported. Where is this list located?
> >>> So the overall plan, as I understand it:
> >>> 1) Finish writing tests for configurations listed in the matrix
> >>> 2) Verify the tests work with the 0.92 release and report any
> >>> issues
> >>> 3) Automate the tests with meta.sh
> >> Full automation of meta.sh is not required for 0.92. Let's start by
> >> using
> >> it to create an outline of what it could do via ssh. Once we see
> >> what that
> >> looks like we can turn it into a real tool.
> >>> 4) Make these verified configurations available to users via a
> >>> well
> >>> documented swift road map
> >>> In terms of directory structure for site tests.. if I want to
> >>> create a
> >>> specific test for PADS, for example, should I create it within
> >>> tests/providers/local-pbs/PADS/?
> >> This looks good.
> >> Justin M Wozniak
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
