Fwd: [Swift-devel] Swift hang
Allan Espinosa aespinosa at cs.uchicago.edu
Wed Jan 5 14:42:51 CST 2011
forgot to include the listhost in the earlier thread.
---------- Forwarded message ----------
Date: 2011/1/5
Subject: Re: [Swift-devel] Swift hang
To: Allan Espinosa <aespinosa at cs.uchicago.edu>
Here is the jstack track
--(14:29:%)-- jstack -l 10232
             --(Wed,Jan05)--
2011-01-05 14:29:28
Full thread dump Java HotSpot(TM) 64-Bit Server VM (17.1-b03 mixed mode):
"Attach Listener" daemon prio=10 tid=0x0000000048490800 nid=0x3d25
waiting on condition [0x0000000000000000]
   java.lang.Thread.State: RUNNABLE
   Locked ownable synchronizers:
    - None
"Sender" daemon prio=10 tid=0x000000004823f000 nid=0x2a0b in
Object.wait() [0x00000000446c5000]
   java.lang.Thread.State: WAITING (on object monitor)
    at java.lang.Object.wait(Native Method)
    at java.lang.Object.wait(Object.java:485)
    at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:241)
    - locked <0x00002aaab5490a50> (a
org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender)
    - None
"PullThread" daemon prio=10 tid=0x0000000048240800 nid=0x2a0a in
Object.wait() [0x00000000445c4000]
   java.lang.Thread.State: TIMED_WAITING (on object monitor)
    at org.globus.cog.abstraction.coaster.service.job.manager.PullThread.mwait(PullThread.java:86)
    at org.globus.cog.abstraction.coaster.service.job.manager.PullThread.run(PullThread.java:57)
    - locked <0x00002aaab5490d28> (a
org.globus.cog.abstraction.coaster.service.job.manager.PullThread)
    - None
"Channel multiplexer 1" daemon prio=10 tid=0x00000000479a2800
nid=0x2a08 sleeping[0x00000000443c2000]
   java.lang.Thread.State: TIMED_WAITING (sleeping)
    at java.lang.Thread.sleep(Native Method)
    at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Multiplexer.run(AbstractStreamKarajanChannel.java:418)
    - None
"Channel multiplexer 0" daemon prio=10 tid=0x0000000047a62800
nid=0x2a07 sleeping[0x00000000444c3000]
    - None
"Timer-3" daemon prio=10 tid=0x0000000047a62000 nid=0x2a06 in
Object.wait() [0x0000000043ebd000]
    at java.util.TimerThread.mainLoop(Timer.java:509)
    - locked <0x00002aaab54afbf0> (a java.util.TaskQueue)
    at java.util.TimerThread.run(Timer.java:462)
    - None
"PBS provider queue poller" daemon prio=10 tid=0x0000000048405000
nid=0x29bd sleeping[0x0000000043dbc000]
    at org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller.run(AbstractQueuePoller.java:76)
    at java.lang.Thread.run(Thread.java:662)
    - None
"Block Submitter" daemon prio=10 tid=0x00002aacc4016800 nid=0x2978 in
Object.wait() [0x00000000441c0000]
    at org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run(BlockTaskSubmitter.java:54)
    - locked <0x00002aaab54d4510> (a java.util.LinkedList)
    - None
"Timer-2" daemon prio=10 tid=0x00000000483e7800 nid=0x2952 in
Object.wait() [0x0000000043cbb000]
    at java.util.TimerThread.mainLoop(Timer.java:483)
    - locked <0x00002aaab54caa88> (a java.util.TaskQueue)
    - None
"Piped Channel Sender" daemon prio=10 tid=0x0000000048403800
nid=0x2951 in Object.wait() [0x0000000043bba000]
    at edu.emory.mathcs.backport.java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:315)
    - locked <0x00002aaab54acd38> (a
edu.emory.mathcs.backport.java.util.concurrent.LinkedBlockingQueue$SerializableLock)
    at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:113)
    - None
"Piped Channel Sender" daemon prio=10 tid=0x0000000047a04800
nid=0x2950 in Object.wait() [0x0000000043ab9000]
    - locked <0x00002aaab54ac848> (a
    - None
"Local Queue Processor" daemon prio=10 tid=0x0000000048407000
nid=0x294f in Object.wait() [0x00000000439b8000]
    - waiting on <0x00002aaab548bed8> (a org.globus.cog.karajan.util.Queue)
    at org.globus.cog.karajan.util.Queue.take(Queue.java:46)
    - locked <0x00002aaab548bed8> (a org.globus.cog.karajan.util.Queue)
    at org.globus.cog.abstraction.coaster.service.job.manager.AbstractQueueProcessor.take(AbstractQueueProcessor.java:51)
    at org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:37)
    - None
"Server: http://192.5.86.6:46247" daemon prio=10
tid=0x0000000047b66000 nid=0x294e runnable [0x00000000438b7000]
    at java.net.PlainSocketImpl.socketAccept(Native Method)
    at java.net.PlainSocketImpl.accept(PlainSocketImpl.java:390)
    - locked <0x00002aaab5492b68> (a java.net.SocksSocketImpl)
    at java.net.ServerSocket.implAccept(ServerSocket.java:453)
    at java.net.ServerSocket.accept(ServerSocket.java:421)
    at org.globus.net.BaseServer.run(BaseServer.java:226)
    - None
"Timer-1" daemon prio=10 tid=0x00000000487ab000 nid=0x294c in
Object.wait() [0x00000000436b5000]
    - locked <0x00002aaab5518710> (a java.util.TaskQueue)
    - None
"Coaster Bootstrap Service Connection Processor" daemon prio=10
tid=0x0000000047c99000 nid=0x294a runnable [0x00000000435b4000]
    at sun.nio.ch.EPollArrayWrapper.epollWait(Native Method)
    at sun.nio.ch.EPollArrayWrapper.poll(EPollArrayWrapper.java:210)
    at sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:65)
    at sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:69)
    - locked <0x00002aaab5474d40> (a sun.nio.ch.Util$1)
    - locked <0x00002aaab5474d28> (a java.util.Collections$UnmodifiableSet)
    - locked <0x00002aaab5474998> (a sun.nio.ch.EPollSelectorImpl)
    at sun.nio.ch.SelectorImpl.select(SelectorImpl.java:80)
    at sun.nio.ch.SelectorImpl.select(SelectorImpl.java:84)
    at org.globus.cog.abstraction.impl.execution.coaster.BootstrapService$ConnectionProcessor.run(BootstrapService.java:231)
    - None
"Coaster Bootstrap Service Thread" daemon prio=10
tid=0x0000000047c30800 nid=0x2949 runnable [0x00000000434b3000]
    at sun.nio.ch.ServerSocketChannelImpl.accept0(Native Method)
    at sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:145)
    - locked <0x00002aaab54746f8> (a java.lang.Object)
    at org.globus.cog.abstraction.impl.execution.coaster.BootstrapService.run(BootstrapService.java:184)
    - None
"Local service" daemon prio=10 tid=0x0000000047c49800 nid=0x2948
runnable [0x00000000433b2000]
    - locked <0x00002aaab5489de8> (a java.net.SocksSocketImpl)
    - None
"Scheduler" prio=10 tid=0x00002aacc01ae800 nid=0x28b5 in Object.wait()
[0x0000000042dac000]
    at org.globus.cog.karajan.scheduler.LateBindingScheduler.sleep(LateBindingScheduler.java:305)
    at org.globus.cog.karajan.scheduler.LateBindingScheduler.run(LateBindingScheduler.java:289)
    - locked <0x00002aaab500e070> (a
org.griphyn.vdl.karajan.VDSAdaptiveScheduler)
    - None
"Progress ticker" daemon prio=10 tid=0x000000004821d000 nid=0x281e
waiting on condition [0x0000000042cab000]
    at org.griphyn.vdl.karajan.lib.RuntimeStats$ProgressTicker.run(RuntimeStats.java:137)
    - None
"Restart Log Sync" daemon prio=10 tid=0x0000000048219800 nid=0x281d in
Object.wait() [0x0000000042baa000]
    at org.globus.cog.karajan.workflow.nodes.restartLog.SyncThread.run(SyncThread.java:45)
    - locked <0x00002aaab4b71708> (a
org.globus.cog.karajan.workflow.nodes.restartLog.SyncThread)
    - None
"Overloaded Host Monitor" daemon prio=10 tid=0x00000000486b7000
nid=0x2819 waiting on condition [0x0000000042aa9000]
    at org.globus.cog.karajan.scheduler.OverloadedHostMonitor.run(OverloadedHostMonitor.java:47)
    - None
"Timer-0" daemon prio=10 tid=0x0000000048632000 nid=0x2816 in
Object.wait() [0x00000000429a8000]
    - locked <0x00002aaab51e2ea0> (a java.util.TaskQueue)
    - None
"pool-1-thread-8" prio=10 tid=0x000000004849c000 nid=0x2814 in
Object.wait() [0x00000000427a6000]
    - locked <0x00002aaab405e590> (a
    at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:470)
    at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:667)
    - None
"pool-1-thread-7" prio=10 tid=0x000000004807e800 nid=0x2813 in
Object.wait() [0x00000000426a5000]
    - None
"pool-1-thread-6" prio=10 tid=0x000000004855f000 nid=0x2812 in
Object.wait() [0x00000000425a4000]
    - None
"pool-1-thread-5" prio=10 tid=0x00000000486c9800 nid=0x2811 in
Object.wait() [0x00000000424a3000]
    - None
"pool-1-thread-4" prio=10 tid=0x00000000486c8000 nid=0x2810 in
Object.wait() [0x00000000423a2000]
    - None
"pool-1-thread-3" prio=10 tid=0x0000000048491800 nid=0x280f in
Object.wait() [0x00000000422a1000]
    - None
"pool-1-thread-2" prio=10 tid=0x00000000482d8800 nid=0x280e in
Object.wait() [0x00000000412dd000]
    - None
"pool-1-thread-1" prio=10 tid=0x00002aacc0018000 nid=0x280d in
Object.wait() [0x000000004104d000]
    - None
"Low Memory Detector" daemon prio=10 tid=0x00002aacb8026000 nid=0x2808
runnable [0x0000000000000000]
    - None
"CompilerThread1" daemon prio=10 tid=0x00002aacb8023800 nid=0x2807
    - None
"CompilerThread0" daemon prio=10 tid=0x00002aacb8020800 nid=0x2806
    - None
"Signal Dispatcher" daemon prio=10 tid=0x00002aacb801e000 nid=0x2805
    - None
"Finalizer" daemon prio=10 tid=0x000000004796c000 nid=0x2804 in
Object.wait() [0x0000000041f9e000]
    at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:118)
    - locked <0x00002aaab3e096b8> (a java.lang.ref.ReferenceQueue$Lock)
    at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:134)
    at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:159)
    - None
"Reference Handler" daemon prio=10 tid=0x0000000047965000 nid=0x2803
in Object.wait() [0x0000000041c29000]
    at java.lang.ref.Reference$ReferenceHandler.run(Reference.java:116)
    - locked <0x00002aaab3e09630> (a java.lang.ref.Reference$Lock)
    - None
"main" prio=10 tid=0x00000000478fb800 nid=0x27f9 in Object.wait()
[0x0000000040dd9000]
    - waiting on <0x00002aaab47b9dc0> (a
org.griphyn.vdl.karajan.VDL2ExecutionContext)
    at org.globus.cog.karajan.workflow.ExecutionContext.waitFor(ExecutionContext.java:261)
    - locked <0x00002aaab47b9dc0> (a
    at org.griphyn.vdl.karajan.Loader.main(Loader.java:197)
    - None
"VM Thread" prio=10 tid=0x0000000047960800 nid=0x2802 runnable
"GC task thread#0 (ParallelGC)" prio=10 tid=0x000000004790e800
nid=0x27fa runnable
"GC task thread#1 (ParallelGC)" prio=10 tid=0x0000000047910000
nid=0x27fb runnable
"GC task thread#2 (ParallelGC)" prio=10 tid=0x0000000047912000
nid=0x27fc runnable
"GC task thread#3 (ParallelGC)" prio=10 tid=0x0000000047914000
nid=0x27fd runnable
"GC task thread#4 (ParallelGC)" prio=10 tid=0x0000000047915800
nid=0x27fe runnable
"GC task thread#5 (ParallelGC)" prio=10 tid=0x0000000047917800
nid=0x27ff runnable
"GC task thread#6 (ParallelGC)" prio=10 tid=0x0000000047919800
nid=0x2800 runnable
"GC task thread#7 (ParallelGC)" prio=10 tid=0x000000004791b000
nid=0x2801 runnable
"VM Periodic Task Thread" prio=10 tid=0x00002aacb8038800 nid=0x2809
JNI global references: 1451
On 1/5/11 2:06 PM, Allan Espinosa wrote:
Hi jon,
Could you post a jstack trace? It should indicate if the code has deadlocks.
-Allan (mobile)
On Jan 5, 2011 4:50 PM, "Jonathan Monette" <jon.monette at gmail.com> wrote:
> Hello,
>   I have encountered swift hanging.  The deadlock appears to be in the same place every time.  This deadlock does seem to be intermittent since smaller work sizes does complete.  This job size is with approximately 1200 files.  The behavior that the logs show is that the files needed for the job submission are staged in but no jobs are submitted.  The Coaster heartbeat that appears in the swift logs shows that the job queue is empty.  The logs for the runs are in ~jonmon/Workspace/Swift/Montage/m101_j_6x6/run.000[1,2,3]  I will try to recreate the problem using simple cat jobs.
> Jon
> Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
> - Albert Einstein
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Jon
beyond imagination.
- Albert Einstein
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
