[Swift-devel] Error in Swift mapping
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb 28 13:10:24 CST 2011
Does this happen on every run?
I suspect it might be due to somehow a future event getting fired twice,
but I can see the code path that would cause this.
Mihael
On Mon, 2011-02-28 at 01:51 -0800, Mihael Hategan wrote:
> Nevermind. It must be trunk.
> On Mon, 2011-02-28 at 01:47 -0800, Mihael Hategan wrote:
> > Trunk or stable branch?
> > On Sat, 2011-02-26 at 13:17 -0600, Jonathan Monette wrote:
> > > The swift version is r4143.  The cog version is r3056.  Attached is the
> > > log file and the script.  It is from my Montage stuff.  This is the
> > > first time this error has appeared.  I have no local mods to Swift.  I
> > > will try to replicate the error in a small script since it seems the
> > > mapping error occurs early on in my script.
> > > On 2/26/11 7:21 AM, Michael Wilde wrote:
> > > > Hi Jon,
> > > > Can you send us the version of Swift you used, any local mods to it, and the full log file and source script.  If possible, a command line that we could replicate it with. ANy chance you could replicate it with a self-contained script that we could re-execute?
> > > > Thanks,
> > > > Mike
> > > > ----- Original Message -----
> > > >> Hello,
> > > >> I seem to have found an error in Swift. Here is the error that
> > > >> Swift reported.
> > > >> Execution failed:
> > > >> swift#mapper#17019 is closed with a value of
> > > >> proj_dir/proj_raw_image_3.fits
> > > >> And here is a portion from the log file.
> > > >> 011-02-25 21:09:48,012-0600 DEBUG VDL2ExecutionContext
> > > >> java.lang.IllegalArgumentException: swift#mapper#17019 is closed with
> > > >> a
> > > >> value of proj_dir/proj_raw_image_3.fits
> > > >> a
> > > >> Caused by: java.lang.IllegalArgumentException: swift#mapper#17019 is
> > > >> closed with a value of proj_dir/proj_raw_image_3.fits
> > > >> at
> > > >> org.griphyn.vdl.mapping.AbstractDataNode.setValue(AbstractDataNode.java:338)
> > > >> at
> > > >> org.griphyn.vdl.mapping.RootDataNode.setValue(RootDataNode.java:218)
> > > >> at
> > > >> org.griphyn.vdl.karajan.lib.SetFieldValue.deepCopy(SetFieldValue.java:88)
> > > >> at
> > > >> org.griphyn.vdl.karajan.lib.SetFieldValue.function(SetFieldValue.java:50)
> > > >> at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:68)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.futureModified(AbstractSequentialWithArguments.java:210)
> > > >> at
> > > >> org.griphyn.vdl.karajan.DSHandleFutureWrapper.notifyListeners(DSHandleFutureWrapper.java:71)
> > > >> at
> > > >> org.griphyn.vdl.karajan.DSHandleFutureWrapper.addModificationAction(DSHandleFutureWrapper.java:60)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:199)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:48)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:196)
> > > >> at
> > > >> at
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
> > > >> at
> > > >> at
> > > >> at
> > > >> at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:72)
> > > >> at
> > > >> at
> > > >> at
> > > >> at
> > > >> at
> > > >> at
> > > >> at
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
> > > >> at
> > > >> org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
> > > >> at
> > > >> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
> > > >> at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
> > > >> at java.util.concurrent.FutureTask.run(FutureTask.java:138)
> > > >> at
> > > >> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
> > > >> at
> > > >> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
> > > >> at java.lang.Thread.run(Thread.java:662)
> > > >> _______________________________________________
> > > >> Swift-devel mailing list
> > > >> Swift-devel at ci.uchicago.edu
> > > >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
