[Swift-devel] Error in Swift mapping
    Jonathan Monette
    jon.monette at gmail.com
    Sat Feb 26 00:22:05 CST 2011
Hello,
     I seem to have found an error in Swift.  Here is the error that
Swift reported.
Execution failed:
     swift#mapper#17019 is closed with a value of
proj_dir/proj_raw_image_3.fits
And here is a portion from the log file.
011-02-25 21:09:48,012-0600 DEBUG VDL2ExecutionContext
java.lang.IllegalArgumentException: swift#mapper#17019 is closed with a
value of proj_dir/proj_raw_image_3.fits
Caused by: java.lang.IllegalArgumentException: swift#mapper#17019 is
closed with a value of proj_dir/proj_raw_image_3.fits
     at
org.griphyn.vdl.mapping.AbstractDataNode.setValue(AbstractDataNode.java:338)
     at org.griphyn.vdl.mapping.RootDataNode.setValue(RootDataNode.java:218)
     at
org.griphyn.vdl.karajan.lib.SetFieldValue.deepCopy(SetFieldValue.java:88)
     at
org.griphyn.vdl.karajan.lib.SetFieldValue.function(SetFieldValue.java:50)
     at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:68)
     at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.futureModified(AbstractSequentialWithArguments.java:210)
     at
org.griphyn.vdl.karajan.DSHandleFutureWrapper.notifyListeners(DSHandleFutureWrapper.java:71)
     at
org.griphyn.vdl.karajan.DSHandleFutureWrapper.addModificationAction(DSHandleFutureWrapper.java:60)
     at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:199)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
     at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
     at
org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:48)
     at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:196)
     at
     at
     at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
     at
     at
     at
     at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:72)
     at
     at
     at
     at
     at
     at
     at
     at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
     at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
     at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
     at
org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
     at
org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
     at
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
     at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
     at java.util.concurrent.FutureTask.run(FutureTask.java:138)
     at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
     at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
     at java.lang.Thread.run(Thread.java:662)
