[Swift-devel] deadlock on workflow:
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Thu Feb 17 16:54:14 CST 2011
Hi Mike,
I haven't tested it yet. I will need my sites.xml definitions to not
use persistent+ passive coasters before being able to test it.
What's the difference in 'explicit' resume?  In my setup i have a
"resumefile" that i've been using for the past few months.
-Allan
2011/2/17 Michael Wilde <wilde at mcs.anl.gov>:
> Allan,
> If you already stated this I missed it: are you able to run on 0.92? And does the deadlock occur there? Is resume working in 0.92?
> And, have you considered using explicit resume based on having your input mapper only return members of the dataset that are not yet competed? (I think Glen Hocky used that technique with good results in his latest Glass runs).
> - Mike
>> Yeah. I'll take a look at that.
>> But the other question is whether the deadlocking version is something
>> that is worth fixing (i.e. a current stable branch or trunk).
>> On Thu, 2011-02-17 at 15:45 -0600, Allan Espinosa wrote:
>> > The latest trunk breaks for another case (see my post on 'broken
>> > resume files'). So I can't reproduce this there (yet).
>> > 2011/2/17 Mihael Hategan <hategan at mcs.anl.gov>:
>> > > Ok. Your deadlock is genuine, but your version of swift seems old.
>> > > Are
>> > > you sure it wasn't fixed in the mean time?
>> > > On Thu, 2011-02-17 at 13:49 -0600, Allan Espinosa wrote:
>> > >> Version
>> > >> swift-r3835 cog-r2988
>> > >> see attached:
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
