[Swift-devel] Proposed sites.xml management for 0.92 release
    David Kelly
    dk0966 at cs.ship.edu
    Mon Feb 14 21:56:15 CST 2011
To store their settings in swift.properties, can I safely create arbitrary
values like gensites.workdirectory=/home/blah?
On Mon, Feb 14, 2011 at 3:11 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> The proposed gensites command is intended to be very simple. It basically
> takes a template and user-set variables, and inserts the variables into the
> template.
> The GenSites spec page proposed that templates can live in the release
> etc/sites dir, the users $HOME/.swift/sites dir, or a -T directory from the
> cmd line.  User settings can live in swift.properties in the current dir or
> $HOME/.swift.  Thats about it.  I think this can be done simply and quickly
> in a shell script.
> - Mike
> On Mon, Feb 14, 2011 at 10:25 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Sarah, David,
>> Yes, I think gathering the site templates is indeed the first step. Then
>> parameterizing them, including provisions for removing lines (per the
>> GetSites spec page).
>> And I agree that we should set swiftrun aside (and later bundle any needed
>> parts of it into the swift command).
>> David, I reviewed the current swiftconfg, and I feel it can be greatly
>> simplified by rewriting as a shell script.
> oh, if we're going to actually do a re-write rather than leverage the code
> david already wrote my preference would be for python over shell...david do
> you know python? if not then shell is *ok* with me, it'll just be a little
> slower and clumsier for me :P i thought if we were sticking with the perl i
> would not help write it but just write the doc, but if we're doing a
> re-write i'm guessing it will take the effort of both of is (?)
>> There is some reasonable shell arg parsing logic we can lift from:
>> https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/SwiftR/Swift/exec/start-swift
>> (arg parsing is right after the usage() function around midway through the
>> script)
>> - Mike
>> ----- Original Message -----
>> sounds good to me david...i don't know perl so maybe my time would be
>> better spent using it and updating the doc in sync with you working on the
>> code (?) i think first we want to separate swiftconfig from swiftrun...it
>> would be good if users who are already used to running regular 'swift' to be
>> able to transition to using swiftconfig (i realize this probably affects the
>> doc more than your code, i just wanted to mention it).
>> so, maybe the first step is switching out the sites templates?
>> On Fri, Feb 11, 2011 at 8:51 PM, David Kelly < dk0966 at cs.ship.edu >
>> wrote:
>> Would it be easier to modify the existing swiftconfig to adjust to the new
>> format of templates?
>> The main steps that were outlined are nearly already completed with
>> swiftconfig
>> - The commands are already there
>> - A set of templates already exists, but would most likely be replaced
>> with the ones verified by automated testing in the format Justin specified
>> - A good start for documentation using swiftconfig on a variety of
>> configurations is at
>> http://www.ci.uchicago.edu/wiki/bin/view/SWFT/LearningSwift
>> - Documentation for commands and syntax is there, swiftconfig -h and
>> swiftrun -h
>> - List all templates with swiftconfig -list templates (already knows the
>> correct order of where to look for templates)
>> - Help for specific templates is a good idea. That would be pretty
>> straightforward to add
>> - Support for applications and application groups is already there
>> If we started over it seems like we would be duplicating a lot of code
>> Michael Wilde
>> Computation Institute, University of Chicago
>> Mathematics and Computer Science Division
>> Argonne National Laboratory
> Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110214/a31734d4/attachment.html>
