[Swift-devel] Re: Fix needed for ppn for non-coaster pbs provider
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Feb 14 13:22:53 CST 2011
I just looked at the file containing this code:
src/org/globus/cog/abstraction/impl/scheduler/pbs/PBSExecutor.java
and its changed a fair bit more from 0.92 to trunk than I can deal with.
Mihael, is this file in 0.92 more recent than the one in trunk, and does it and related changes need to get integrated back into trunk?
Mike
----- Original Message -----
> The recent ppn changes need a small change to work in the case of the
> PBS provider running without coasters. This causes it to put this in
> the .submit file:
> #PBS -l ppn=8
> ...which PBS rejects. The line needs to be:
> #PBS -l nodes=1:ppn=8
> (as alluded to in the comments in PBSExecutor.java)
> Fixing it as above when count is not specified seems to work on PADS.
> svn diff is below.
> I did not commit this. Should I? To trunk, 0.92 branch, or both?
> - Mike
> login1$ cd
> /home/wilde/swift/src/0.92/cog/modules/provider-localscheduler/
> login1$ svn diff
> Index:
> --- src/org/globus/cog/abstraction/impl/scheduler/pbs/PBSExecutor.java
> (revision 3046)
> +++ src/org/globus/cog/abstraction/impl/scheduler/pbs/PBSExecutor.java
> (working copy)
> @@ -68,7 +68,7 @@
> // 1. assuming count=1 when count is missing
> // 2. not specifying PPN when count is missing
> // ... are any better
> - wr.write("#PBS -l ppn=" + ppn + "\n");
> + wr.write("#PBS -l nodes=1:ppn=" + ppn + "\n");
> login1$
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Michael Wilde
