[Swift-devel] Re: fixed_array_mapper versus array_mapper on output
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb 14 12:44:09 CST 2011
I made the array_mapper static in swift trunk r4089.
It seems that the code in there assumes that the files= argument is a
closed array anyway. I am not entirely convinced this would work ok, but
please give it a try.
Another solution might be to add a @join function and then use the fixed
array mapper.
Mihael
On Mon, 2011-02-14 at 02:11 -0600, Allan Espinosa wrote:
> Making my question more concrete, how you suggest going about my workflow:
>  string seis_str[];
>   string peak_str[];
>   foreach var,i in vars {
>     seis_str[i] = @strcat(loc_sub, "/Seismogram_", site.name, "_", rup.source,
>                           "_", rup.index, "_", i, ".grm");
>     peak_str[i] = @strcat(loc_sub, "/PeakVals_", site.name, "_", rup.source,
>                           "_", rup.index, "_", i, ".bsa");
>   Seismogram seis[] <array_mapper; files=seis_str>;
>   PeakValue  peak[] <array_mapper; files=peak_str>;
>   (seis, peak) = seispeak_agg(sub, vars, site, rup.size);
> Should I hack around to force this into a fixed_array_mapper?
> -Allan
> 2011/2/12 Allan Espinosa <aespinosa at cs.uchicago.edu>:
> > Moving thread to devel for brainstorming possible solutions:
> > 1.  implement a join() function: @join(array, ", ");
> > 2.  fix array_mapper
> >> For an array output data structure, the two mappers behave differently
> >> type file;
> >> app(file o[])
> >>    split(file i){
> >>  split "-l" 1 @filename(i) "seqout.";
> >> /*file out[] <array_mapper; files=["seqout.aa", "seqout.ab",
> >> "seqout.ac",  // Does not work
> >>                                 "seqout.ad"]>;*/
> >> file out[] <fixed_array_mapper; files="seqout.aa, seqout.ab,
> >> seqout.ac, seqout.ad">; // Works
> >> file input <"seq.in">;
> >> out = split(input);
