[Swift-devel] Re: Needs for site selection and job scheduling enhancements
Michael Wilde
wilde at mcs.anl.gov
Tue Feb 1 19:23:51 CST 2011
----- Original Message -----
> I think we need to slow down a bit :)
Indeed. I'll try to space out my emails better :)
I mainly wanted to get the ideas on the table before we forget them, and also let Dan, Allan, and others comment on them.
I'll follow up on your responses below in a later email.
The main thing to do first is to characterize the IO/compute behavior in the application, show what Swift does currently, and postulate how that could be improved.
- Mike
> On Tue, 2011-02-01 at 08:30 -0600, wilde at mcs.anl.gov wrote:
> > Mihael,
> > Below is a proposal for Swift scheduling features that will need a
> > fair amount of deliberation. This email is intended to start the
> > process. I can move this to a bugzila enhancement to start the
> > process, so long as you agree that the discussion makes sense to
> > have.
> > Allan, Dan and I have been re-examining the SCEC workflow that Allan
> > is working on.
> > Doing it efficiently on OSG raises scheduling aspects that Swift
> > still
> > doesn't handle well. We propose to address these issues in two
> > phases:
> I think it may be useful to spell those out.
> > I. Use simple workflows that group more work into single scripts to
> > achieve the job affinities needed for reasonable performance.
> > Provide
> > scheduling hints to Swift.
> > II. Determine how Swift could automatically achieve the same
> > scheduling decisions.
> > Phase II is pretty complex as far as we can tell, so lets defer its
> > discussion.
> > To do phase I, we want to ask if any of the following capabilities
> > could be added, and which ones are both reasonable and of
> > "affordable"
> > cost and make sense to try.
> > Most of these involve enabling a Swift script to specify scheduling
> > "hints" on individual app() invocations.
> Does the place where the hints are specified have any relevance? If we
> put the hints in the swift source we lose the "site independence"
> aspect.
> > And we might need a feature (perhaps a swift.properties setting) to
> > tell Swift to defer initial scheduling decisions for N seconds or
> > until J jobs have been queued by the script, so that a sufficiently
> > large number of jobs are in the queue before scheduling decisions
> > are
> > made (probably delay for say a minute on a multi-hour script run).
> How would that help? Given that the scheduling is probabilistic, that
> makes the distribution essentially the same whether you have N or N/2
> jobs.
> > In addition, we're wondering how easy (and desirable) any/all of the
> > following language extensions could be done:
> > - select statement to work on string values and/or ranges
> What would be the semantics of this statement? Can you give examples?
> > - elseif clause to achieve the above in a multi-branch if statement
> Quite silly we don't support that already.
> > - function pointers to select a function dynamically, eg from an
> > array
> Well, I do like the idea of higher order functions, but that's not
> quite
> the way we went with this in the start. Though I'm sure it could be
> added. However, I would be curious to see the kind of problem that one
> would solve with swift that would require this.
> > - ability to set the app program name from a variable
> Could you clarify that?
> > These enhancements would enable us to manually code in the
> > scheduling
> > hints by providing multiple pool groups with different throttle
> > settings and to manually force jobs to different pools.
> I feel that to be a contrived way to avoid java code. Things are
> separated into components in order to isolate solutions to subproblems
> into loosely connected parts of the code. The idea that we'd implement
> scheduling features in the swift language seems to be the antithesis
> of
> that design principle.
> > If the easiest way to set the hints requested above on an individual
> > job is to pass an env var on the command line, then that capability
> > might be a useful alternative to setting env vars with
> > one-value-for-all method that we currently employ with the ENV
> > profile. This could be considered as a useful enhancement separate
> > from the question of how scheduling hints are set.
> > Lastly, in phase I we will be testing the performance of having the
> > jobs "pull" files via wget in a pre-staged manner, within the
> > applicaton script. For Phase II we'd like to consider having Swift
> > do
> > that in the worker: Have the coaster worker "pull" files in via wget
> > or similar command/function, asynchronously pre-staging files for
> > jobs
> > that have been queued/assigned to a site. But that can be deferred
> > for
> > a later discussion.
> How is that different from the current worker staging mechanism (aside
> from changing protocols and tools)? I.e., what is the theoretical
> difference?
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
