[Swift-devel] swift on ranger
    David Kelly
    davidk at ci.uchicago.edu
    Wed Dec 21 09:44:59 CST 2011
Yep, very good idea.
----- Original Message -----
> From: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Wednesday, December 21, 2011 9:40:22 AM
> Subject: Re: [Swift-devel] swift on ranger
> Should we provide an option to copy the submit file text into the log?
> On Wed, 21 Dec 2011, David Kelly wrote:
> > Sarah,
> > Could you please send the submit files that were generated from this
> > run? That should help narrow it down a bit.
> > Thanks,
> > David
> >> From: "Sarah Kenny" <skenny at uci.edu>
> >> To: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Swift User"
> >> <swift-user at ci.uchicago.edu>
> >> Sent: Wednesday, December 21, 2011 6:57:32 AM
> >> Subject: [Swift-devel] swift on ranger
> >> getting this when submitting to ranger with both the latest and our
> >> previous version of swift (swift-r5259 cog-r3313)
> >> Final status: time: Wed, 21 Dec 2011 04:49:15 -0800 Finished
> >> successfully:100
> >> The following warnings have occurred:
> >> 1.
> >> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> >> Cannot submit job: Could not submit job (qsub reported an exit code
> >> of
> >> 1).
> >> Welcome to TACC's Ranger System, an NSF XD Resource
> >> Checking that you specified -V...--> Checking that you specified a
> >> time limit...--> Checking that you specified a queue...--> Setting
> >> project...--> Checking that you specified a parallel
> >> environment...-->
> >> Checking that you specified a valid parallel environment name...-->
> >> Checking that the minimum and maximum PE counts are the same...-->
> >> Checking that the number of PEs requested is
> >> valid...------------------> Rejecting job <------------------Your
> >> slot
> >> (or core) request is not a multiple of 16.Syntax: -pe <pe_name>
> >> <n>where <n> is a multiple of
> >> 16.-----------------------------------------------------
> >> Unable to run job: JSV rejected job.Exiting.
> >> at
> >> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
> >> at
> >> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
> >> at
> >> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:57)
> >> at
> >> org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
> >> Caused by:
> >> org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
> >> Could not submit job (qsub reported an exit code of 1).
> >> environment...-->
> >> slot
> >> at
> >> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:108)
> >> at
> >> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
> >> ... 3 more
> >> ################### sites file
> >> <config>
> >> <pool handle="RANGER">
> >> <execution provider="coaster" jobManager="gt2:SGE" url="
> >> gatekeeper.ranger.tacc.teragrid.org "/>
> >> <filesystem provider="gsiftp" url="gsiftp://
> >> gridftp.ranger.tacc.teragrid.org "/>
> >> <profile namespace="globus" key="maxtime">86400</profile>
> >> <profile namespace="globus" key="maxWallTime">02:00:00</profile>
> >> <profile namespace="globus" key="jobsPerNode">1</profile>
> >> <profile namespace="globus" key="nodeGranularity">64</profile>
> >> <profile namespace="globus" key="maxNodes">4096</profile>
> >> <profile namespace="globus" key="queue">normal</profile>
> >> <profile namespace="karajan" key="jobThrottle">1.28</profile>
> >> <profile namespace="globus" key="project">TG-DBS080004N</profile>
> >> <profile namespace="globus" key="pe">16way</profile>
> >> <profile namespace="karajan" key="initialScore">10000</profile>
> >> <workdirectory>/work/00043/tg457040/swiftwork</workdirectory>
> >> </pool>
> >> </config>
> >> same settings we've been using for a while, i'm not sure why this
> >> seems to be popping up now, but it's rather consistent. all jobs
> >> are
> >> finishing successfully, so it's rather confusing...any idea what i
> >> might be missing here?
> >> thanks
> >> ~sk
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Justin M Wozniak
