[Swift-devel] CFP: 4th Workshop on Many-Task Computing on Grids and Supercomputers (MTAGS) 2011 -- co-located with IEEE/ACM Supercomputing 2011
    Ioan Raicu
    iraicu at cs.iit.edu
    Wed Aug 31 02:37:08 CDT 2011
    (MTAGS) 2011
*http://datasys.cs.iit.edu/events/MTAGS11/index.html *
*Co-located with * *Supercomputing/SC 2011*
<http://sc11.supercomputing.org/> *
Seattle Washington -- November 14th, 2011*
        News
  * *Keynote Speaker: *Professor David Abramson from Monash University,
    Australia
  * *Special Issue on Data Intensive Computing in the Clouds in the
    Springer Journal of Grid Computing*
    <http://datasys.cs.iit.edu/events/JGC-DataCloud-2012/index.html>
  * *The Second International Workshop on Data Intensive Computing in
    the Clouds (DataCloud-SC11) 2011, co-located at Supercomputing/SC
    2011, November 14th, 2011
    <http://datasys.cs.iit.edu/events/DataCloud-SC11/index.html>*
        Overview
The 4th workshop on Many-Task Computing on Grids and Supercomputers
(MTAGS) will provide the scientific community a dedicated forum for
presenting new research, development, and deployment efforts of
large-scale many-task computing (MTC) applications on large scale
clusters, Grids, Supercomputers, and Cloud Computing infrastructure.
MTC, the theme of the workshop encompasses loosely coupled applications,
which are generally composed of many tasks (both independent and
dependent tasks) to achieve some larger application goal.  This workshop
will cover challenges that can hamper efficiency and utilization in
running applications on large-scale systems, such as local resource
manager scalability and granularity, efficient utilization of raw
hardware, parallel file system contention and scalability, data
management, I/O management, reliability at scale, and application
scalability. We welcome paper submissions on all topics related to MTC
on large scale systems.  Papers will be peer-reviewed, and accepted
papers will be published in the workshop proceedings as part of the ACM
digital library (pending approval). The workshop will be co-located with
the IEEE/ACM Supercomputing 2011 Conference in Seattle Washington on
November 14th, 2011.
For more information, please see
<http://datasys.cs.iit.edu/events/MTAGS11/index.html>. For more
information on past workshops, please see MTAGS10
<http://datasys.cs.iit.edu/events/MTAGS10/index.html>, MTAGS09
<http://datasys.cs.iit.edu/events/MTAGS09/index.html>, and MTAGS08
<http://datasys.cs.iit.edu/events/MTAGS08/index.html>. We also ran a
Special Issue on Many-Task Computing in the IEEE Transactions on
Parallel and Distributed Systems (TPDS)
<http://datasys.cs.iit.edu/events/TPDS_MTC/index.html> which has
appeared in June 2011; the proceedings can be found online at
http://www.computer.org/portal/web/csdl/abs/trans/td/2011/06/ttd201106toc.htm.
We, the workshop organizers, also published two papers that are highly
relevant to this workshop. One paper is titled "Toward Loosely Coupled
Programming on Petascale Systems
<http://www.cs.iit.edu/%7Eiraicu/research/publications/2008_SC08_Falkon_BGP.pdf>",
and was published in SC08 <http://sc08.supercomp.org/>; the second paper
is titled "Many-Task Computing for Grids and Supercomputers
<http://www.cs.iit.edu/%7Eiraicu/research/publications/2008_MTAGS08_MTC.pdf>",
which was published in MTAGS08
        Topics
We invite the submission of original work that is related to the topics
below. The papers can be either short (5 pages) position papers, or long
(10 pages) research papers. Topics of interest include (in the context
of Many-Task Computing):
  *   Compute Resource Management
      o Scheduling
      o Job execution frameworks
      o Local resource manager extensions
      o Performance evaluation of resource managers in use on large
        scale systems
      o Dynamic resource provisioning
      o Techniques to manage many-core resources and/or GPUs
      o Challenges and opportunities in running many-task workloads on
        HPC systems
  *   Storage architectures and implementations
      o Distributed file systems
      o Parallel file systems
      o Distributed meta-data management
      o Content distribution systems for large data
      o Data caching frameworks and techniques
      o Data management within and across data centers
      o Data-aware scheduling
      o Data-intensive computing applications
      o Eventual-consistency storage usage and management
  *   Programming models and tools
      o Map-reduce and its generalizations
      o Many-task computing middleware and applications
      o Parallel programming frameworks
      o Ensemble MPI techniques and frameworks
      o Service-oriented science applications
  *   Large-Scale Workflow Systems
      o Workflow system performance and scalability analysis
      o Scalability of workflow systems
      o Workflow infrastructure and e-Science middleware
      o Programming Paradigms and Models
  *   Large-Scale Many-Task Applications
      o High-throughput computing (HTC) applications
      o Data-intensive applications
      o Quasi-supercomputing applications, deployments, and experiences
      o Performance Evaluation
  *   Performance evaluation
      o Real systems
      o Simulations
      o Reliability of large systems
        Important Dates
  * Abstract submission: September 2, 2011
  * Paper submission: September 9, 2011
  * Acceptance notification: October 7, 2011
  * Final papers due: October 28, 2011
        Paper Submission
Authors are invited to submit papers with unpublished, original work of
not more than 10 pages of double column text using single spaced 10
point size on 8.5 x 11 inch pages, as per ACM 8.5 x 11 manuscript
guidelines
(http://www.acm.org/publications/instructions_for_proceedings_volumes);
document templates can be found at
http://www.acm.org/sigs/publications/proceedings-templates. We are also
seeking position papers of no more than 5 pages in length. A 250 word
abstract (PDF format) must be submitted online at
https://cmt.research.microsoft.com/MTAGS2011/ before the deadline of
September 2nd, 2011 at 11:59PM PST; the final 5/10 page papers in PDF
format will be due on September 9th, 2011 at 11:59PM PST. Papers will be
peer-reviewed, and accepted papers will be published in the workshop
proceedings as part of the ACM digital library (pending approval).
Notifications of the paper decisions will be sent out by October 7th,
2011. Selected excellent work may be eligible for additional
post-conference publication as journal articles or book chapters, such
as the previous Special Issue on Many-Task Computing in the IEEE
Transactions on Parallel and Distributed Systems (TPDS)
appeared in June 2011. Submission implies the willingness of at least
one of the authors to register and present the paper. For more
information, please http://datasys.cs.iit.edu/events/MTAGS11/
<http://datasys.cs.iit.edu/events/MTAGS11/index.html>, or send email to
mtags11-chairs at datasys.cs.iit.edu
<mailto:mtags11-chairs at datasys.cs.iit.edu>.
        Organization
        <http://datasys.cs.iit.edu/events/MTAGS11/organization.html>
*General Chairs (mtags11-chairs at datasys.cs.iit.edu
<mailto:mtags11-chairs at datasys.cs.iit.edu>)*
  * Ioan Raicu, Illinois Institute of Technology & Argonne National
    Laboratory, USA
  * Ian Foster, University of Chicago & Argonne National Laboratory, USA
  * Yong Zhao, University of Electronic Science and Technology of China,
    China
*Steering Committee*
  * David Abramson, Monash University, Australia
  * Jack Dongara, University of Tennessee, USA
  * Geoffrey Fox, Indiana University, USA
  * Manish Parashar, Rutgers University, USA
  * Marc Snir, University of Illinois at Urbana Champaign, USA
  * Xian-He Sun, Illinois Institute of Technology, USA
  * Weimin Zheng, Tsinghua University, China
*Program Committee*
  * Roger Barga, Microsoft Research, USA
  * Mihai Budiu, Microsoft Research, USA
  * Rajkumar Buyya, University of Melbourne, Australia
  * Catalin Dumitrescu, Fermi National Labs, USA
  * Alexandru Iosup, Delft University of Technology, Netherlands
  * Florin Isaila, Universidad Carlos III de Madrid, Spain
  * Kamil Iskra, Argonne National Laboratory, USA
  * Hui Jin, Illinois Institute of Technology, USA
  * Daniel S. Katz, University of Chicago, USA
  * Tevfik Kosar, Louisiana State University, USA
  * Zhiling Lan, Illinois Institute of Technology, USA
  * Reagan Moore, University of North Carolina, Chappel Hill, USA
  * Jose Moreira, IBM Research, USA
  * Marlon Pierce, Indiana University, USA
  * Judy Qiu, Indiana University, USA
  * Lavanya Ramakrishnan, Lawrence Berkeley National Laboratory, USA
  * Matei Ripeanu, University of British Columbia, Canada
  * Alain Roy, University of Wisconsin, Madison, USA
  * Edward Walker, Texas Advanced Computing Center, USA
  * Mike Wilde, University of Chicago & Argonne National Laboratory, USA
  * Matthew Woitaszek, The University Corporation for Atmospheric
    Research, USA
  * Ken Yocum, University of California at San Diego, USA
Ioan Raicu, Ph.D.
Assistant Professor, Illinois Institute of Technology (IIT)
Guest Research Faculty, Argonne National Laboratory (ANL)
Data-Intensive Distributed Systems Laboratory, CS/IIT
Distributed Systems Laboratory, MCS/ANL
Cel:    1-847-722-0876
Office: 1-312-567-5704
Email:  iraicu at cs.iit.edu
Web:    http://www.cs.iit.edu/~iraicu/
Web:    http://datasys.cs.iit.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110831/ee52b01e/attachment.html>
