[Swift-devel] Notes from 0.93 meeting
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 25 16:42:04 CDT 2011
Right. Or just grab the tacc legacy CA from here:
http://www.tacc.utexas.edu/CA/
On Thu, 2011-08-25 at 14:38 -0700, Sarah Kenny wrote:
> communicado's certs (/etc/grid-security/certificates) are
> out-of-date...if you copy ranger's /etc/grid-security/certificates
> directory to communicado and point yr X509_CERT_DIR to it you can get
> a job thru (a simple globus-job-run with my vaild cert fails from
> communicado at the moment if i don't do this).
> i set our machines at uci to update daily...i think it's less
> frequently at ci...
> On Thu, Aug 25, 2011 at 2:17 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         Can you try a globus-url-copy to gridftp.ranger?
>         gridftp.ranger seems to have the NCSA myproxy CA. You say you
>         have the
>         proper certificates dir in your X509_CERT_DIR, and that
>         directory
>         contains the TACC root cert. So it should work. And so should
>         swift.
>         Though I think that jglobus should be more clear about
>         "Unknown ca"
>         errors. At least the name of the unknown CA should be part of
>         the error
>         message.
>         On Thu, 2011-08-25 at 15:55 -0500, David Kelly wrote:
>         > $ grid-proxy-info -all
>         > subject  : /C=US/O=National Center for Supercomputing
>         Applications/CN=David Kelly
>         > issuer   : /C=US/O=National Center for Supercomputing
>         Applications/OU=Certificate Authorities/CN=MyProxy
>         > identity : /C=US/O=National Center for Supercomputing
>         > type     : end entity credential
>         > strength : 1024 bits
>         > path     : /tmp/x509up_u1878
>         > timeleft : 9:56:53
>         > ----- Original Message -----
>         > > From: "Mihael Hategan" <hategan at mcs.anl.gov>
>         > > To: "David Kelly" <davidk at ci.uchicago.edu>
>         > > Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>,
>         "swift-devel Devel" <swift-devel at ci.uchicago.edu>
>         > > Sent: Thursday, August 25, 2011 3:42:57 PM
>         > > Subject: Re: [Swift-devel] Notes from 0.93 meeting
>         > > Odd. Can you paste the output of 'grid-proxy-info -all'?
>         > > On Thu, 2011-08-25 at 15:18 -0500, David Kelly wrote:
>         > > > Sure, here is the full log:
>         http://www.ci.uchicago.edu/~davidk/001-catsn-ranger-20110825-1515-5tydro91.log
>         "swift-devel
>         > > > > Sent: Thursday, August 25, 2011 2:43:31 PM
>         > > > > It's possible that the CA dir on Ranger is not
>         properly set up.
>         > > > > Can
>         > > > > you
>         > > > > post the full log?
>         > > > > On Thu, 2011-08-25 at 13:56 -0500, David Kelly wrote:
>         > > > > > Those environment variables were not set up. I have
>         them defined
>         > > > > > now, but I'm still getting the same error.
>         > > > > > [davidk at communicado ranger]$ env |grep 509
>         > > > > > X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
>         > > > > > X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
>         > > > > > [davidk at communicado ranger]$ swift -sites.file
>         sites.xml
>         > > > > > -tc.file
>         > > > > > tc.data 001-catsn-ranger.swift
>         > > > > > Swift svn swift-r4987 (swift modified locally)
>         cog-r3229
>         > > > > > RunID: 20110825-1352-f1v940b4
>         > > > > > Progress: time: Thu, 25 Aug 2011 13:52:59 -0500
>         > > > > > Progress: time: Thu, 25 Aug 2011 13:53:00 -0500
>         Selecting site:7
>         > > > > > Initializing site shared directory:3
>         > > > > > Execution failed:
>         > > > > >       Authentication failed [Caused by: Failure
>         unspecified at
>         > > > > >       GSS-API
>         > > > > >       level [Caused by: Unknown CA]]
>         > > > > > > From: "Ketan Maheshwari"
>         > > > > > > Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>,
>         "swift-devel
>         > > > > > > Devel"
>         > > > > > > Sent: Thursday, August 25, 2011 1:32:50 PM
>         > > > > > > Hi,
>         > > > > > > Are your CADIR and CACERT env vars set up?
>         > > > > > > [communicado:swiftgrid]$ echo $X509_CADIR
>         > > > > > > [communicado:swiftgrid]$ echo $X509_CERT_DIR
>         > > > > > > On Thu, Aug 25, 2011 at 1:29 PM, David Kelly <
>         > > > > > > > wrote:
>         > > > > > > Thanks Jon,
>         > > > > > > Here is what happens when I try this from
>         communicado:
>         > > > > > > [davidk at communicado ~]$ myproxy-logon -l dkelly -s
>         > > > > > > myproxy.teragrid.org
>         > > > > > > Enter MyProxy pass phrase:
>         > > > > > > A credential has been received for user dkelly in
>         > > > > > > /tmp/x509up_u1878.
>         sites.xml
>         > > > > > > -tc.file
>         cog-r3229
>         > > > > > > RunID: 20110825-1326-o3e38fe0
>         > > > > > > Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
>         > > > > > > Progress: time: Thu, 25 Aug 2011 13:26:44 -0500
>         Selecting
>         > > > > > > site:8
>         > > > > > > Initializing site shared directory:2
>         > > > > > > Execution failed:
>         unspecified at
>         > > > > > > GSS-API
>         > > > > > > level
>         > > > > > > Any ideas?
>         > > > > > > Thanks,
>         > > > > > > David
>         > > > > > > _______________________________________________
>         > > > > > > Swift-devel mailing list
>         > > > > > > Swift-devel at ci.uchicago.edu
>         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>         > > > > > > Ketan
> Sarah Kenny
> Programmer ~ Brain Circuits Laboratory ~ Rm 2224 Bio Sci III
> University of California Irvine, Dept. of Neurology ~ 773-818-8300
