[Swift-devel] Notes from 0.93 meeting
David Kelly
davidk at ci.uchicago.edu
Thu Aug 25 13:56:02 CDT 2011
Those environment variables were not set up. I have them defined now, but I'm still getting the same error.
[davidk at communicado ranger]$ env |grep 509
X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
[davidk at communicado ranger]$ swift -sites.file sites.xml -tc.file tc.data 001-catsn-ranger.swift
Swift svn swift-r4987 (swift modified locally) cog-r3229
RunID: 20110825-1352-f1v940b4
Progress: time: Thu, 25 Aug 2011 13:52:59 -0500
Progress: time: Thu, 25 Aug 2011 13:53:00 -0500 Selecting site:7 Initializing site shared directory:3
Execution failed:
Authentication failed [Caused by: Failure unspecified at GSS-API level [Caused by: Unknown CA]]
----- Original Message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> Sent: Thursday, August 25, 2011 1:32:50 PM
> Subject: Re: [Swift-devel] Notes from 0.93 meeting
> Hi,
> Are your CADIR and CACERT env vars set up?
> [communicado:swiftgrid]$ echo $X509_CADIR
> [communicado:swiftgrid]$ echo $X509_CERT_DIR
> On Thu, Aug 25, 2011 at 1:29 PM, David Kelly < davidk at ci.uchicago.edu
> > wrote:
> Thanks Jon,
> Here is what happens when I try this from communicado:
> [davidk at communicado ~]$ myproxy-logon -l dkelly -s
> myproxy.teragrid.org
> Enter MyProxy pass phrase:
> A credential has been received for user dkelly in /tmp/x509up_u1878.
> RunID: 20110825-1326-o3e38fe0
> Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
> Progress: time: Thu, 25 Aug 2011 13:26:44 -0500 Selecting site:8
> Initializing site shared directory:2
> Execution failed:
> Any ideas?
> Thanks,
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
