[Swift-devel] Notes from 0.93 meeting
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 25 13:36:45 CDT 2011
That Unknown CA error is normally caused if you don't trust the CA but since Swift is throwing the error this would indicate that Swift does not know about the signing files that is needs to trust the CA.
Do you set X509_CERT_DIR or X509_CA_DIR to anything?
On Aug 25, 2011, at 1:29 PM, David Kelly wrote:
> Thanks Jon,
> Here is what happens when I try this from communicado:
> [davidk at communicado ~]$ myproxy-logon -l dkelly -s myproxy.teragrid.org
> Enter MyProxy pass phrase:
> A credential has been received for user dkelly in /tmp/x509up_u1878.
> [davidk at communicado ranger]$ swift -sites.file sites.xml -tc.file tc.data 001-catsn-ranger.swift
> Swift svn swift-r4987 (swift modified locally) cog-r3229
> RunID: 20110825-1326-o3e38fe0
> Progress:  time: Thu, 25 Aug 2011 13:26:43 -0500
> Progress:  time: Thu, 25 Aug 2011 13:26:44 -0500  Selecting site:8  Initializing site shared directory:2
> Execution failed:
> 	Authentication failed [Caused by: Failure unspecified at GSS-API level [Caused by: Unknown CA]]
> Any ideas?
> Thanks,
> David
