[Swift-devel] Log processing and language reference documentation
    David Kelly
    davidk at ci.uchicago.edu
    Wed Aug 24 15:56:52 CDT 2011
Added it as a chapter in the userguide - docs/userguide/log-processing
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: swift-devel at ci.uchicago.edu, "Justin M Wozniak" <wozniak at mcs.anl.gov>
> Sent: Wednesday, August 24, 2011 3:27:07 PM
> Subject: Re: [Swift-devel] Log processing and language reference documentation
> I vote for including the log doc in the user guide.
> - Mike
> > From: "David Kelly" <davidk at ci.uchicago.edu>
> > To: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> > Cc: swift-devel at ci.uchicago.edu, "Michael Wilde" <wilde at mcs.anl.gov>
> > Sent: Wednesday, August 24, 2011 3:25:27 PM
> > documentation
> > Thanks Justin. I will remove references to the older guide and use
> > the
> > one you mentioned. I'll copy the document to
> > swift/docs/log-processing/log-processing.txt so it can become a part
> > of the nightly build process.
> > David
> > > From: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> > > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > > Cc: "David Kelly" <davidk at ci.uchicago.edu>,
> > > Sent: Wednesday, August 24, 2011 3:02:47 PM
> > > documentation
> > > >> I was just wondering if the log processing documentation on the
> > > >> website is up to date?
> > > > Justin and any users of the log tools, can you comment?
> > > All of the log-processing scripts that I know how to use are
> > > documented
> > > in:
> > > swift/libexec/log-processing/README.txt
> > > This is an asciidoc-formatted file.
> > > >> Also, is there any place to get an up to date list of swift
> > > >> reserved
> > > >> words? It took me a few minutes to figure out why my swift code
> > > >> wasn't
> > > >> compiling. I had named a variable 'in' and it was conflicting
> > > >> with
> > > >> the
> > > >> 'in' used by foreach.
> > > > That would be good to state in the user guide. Mihael, Justin,
> > > > or
> > > > Ben,
> > > > can you comment on this based on your knowledge of the parser?
> > > > Is
> > > > this
> > > > encoded into an ANTLR spec that can be translated into a user
> > > > guide
> > > > table?
> > > I just took another look at swiftscript.g and I don't think there
> > > is
> > > an
> > > easy way to automate this.
> > > Justin
> > > Justin M Wozniak
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
