[Swift-devel] Log processing and language reference documentation
    David Kelly
    davidk at ci.uchicago.edu
    Wed Aug 24 15:25:27 CDT 2011
Thanks Justin. I will remove references to the older guide and use the one you mentioned. I'll copy the document to swift/docs/log-processing/log-processing.txt so it can become a part of the nightly build process.
David
----- Original Message -----
> From: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "David Kelly" <davidk at ci.uchicago.edu>, swift-devel at ci.uchicago.edu
> Sent: Wednesday, August 24, 2011 3:02:47 PM
> Subject: Re: [Swift-devel] Log processing and language reference documentation
> >> I was just wondering if the log processing documentation on the
> >> website is up to date?
> > Justin and any users of the log tools, can you comment?
> All of the log-processing scripts that I know how to use are
> documented
> in:
> swift/libexec/log-processing/README.txt
> This is an asciidoc-formatted file.
> >> Also, is there any place to get an up to date list of swift
> >> reserved
> >> words? It took me a few minutes to figure out why my swift code
> >> wasn't
> >> compiling. I had named a variable 'in' and it was conflicting with
> >> the
> >> 'in' used by foreach.
> > That would be good to state in the user guide. Mihael, Justin, or
> > Ben,
> > can you comment on this based on your knowledge of the parser? Is
> > this
> > encoded into an ANTLR spec that can be translated into a user guide
> > table?
> I just took another look at swiftscript.g and I don't think there is
> an
> easy way to automate this.
> Justin
> Justin M Wozniak
