[Swift-devel] Index out of bounds
    Daniel S. Katz
    dsk at ci.uchicago.edu
    Sat Aug 20 15:14:42 CDT 2011
Yes, write to beagle-support.
On Aug 20, 2011, at 14:52, "Jonathan Monette" <jonmon at mcs.anl.gov> wrote:
> Ok thanks. It seems that I was not added to the beagle-notify list. Could someone point me to a link I can subscribe to? Or do I subscribe by sending mail to beagle-support?
> ----- Reply message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> Date: Sat, Aug 20, 2011 7:45 am
> Subject: [Swift-devel] Index out of bounds
> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
> Cc: <swift-devel at ci.uchicago.edu>
> Yes, Beagle went down yesterday. There was a notice.
> Current status as of Aug 19, 5.30PM:
> At this time, Lustre is not starting properly on Beagle.  This may be related to a configuration change that was made during the last outage.  The effort to restore system availability is still in active progress.
> Ketan
> On Sat, Aug 20, 2011 at 12:03 AM, Jonathan Monette <jonmon at mcs.anl.gov> wrote:
> I updated and rebuilt and added that line to my log4j properties.  Does anyone know if Beagle is down?  showq says there is no service listening to sdb:<number>.  qstat shows that I have a job sitting in the queue but it doesn't look like jobs are running.
> I am using both PADS and Beagle for this execution.  In this case where jobs are not executing on Beagle shouldn't Swift start submitting jobs to PADS?  I do not see that behavior.
> This run is still executing.  But if you would like to look at the log it is at www.ci.uchicago.edu/~jonmon/logs/montage-2.log.  Only 23 tasks have finished before it just sits there waiting for Beagle to run.
> On Aug 19, 2011, at 2:46 PM, Jonathan Monette wrote:
> > Sure can. I add that line to the log4j file or in a different properties file.
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > Date: Fri, Aug 19, 2011 2:03 pm
> > Subject: Index out of bounds
> > Hmm. So I can't see how this manages to happen.
> > I added some checks and debugging statements. Can you update, set log
> > level of org.globus.cog.abstraction.impl.file.local to DEBUG, re-run and
> > then post the log when the exception pops up?
> > Mihael
> > On Thu, 2011-08-18 at 23:14 -0500, Jonathan Monette wrote:
> > > Ok.  The log is at
> > > www.ci.uchicago.edu/~jonmon/logs/montage-1.log
> > > On Aug 18, 2011, at 5:56 PM, Mihael Hategan wrote:
> > > > It's probably a good idea to post the stack trace of that exception now
> > > > rather than later.
> > > > On Thu, 2011-08-18 at 13:09 -0500, Jonathan Monette wrote:
> > > >> Hello,
> > > >>  I was running 0.93 with one a relatively small run, a 350 task run.
> > > >> The run failed on one of the final tasks. I checked the log file and
> > > >> saw some index out of bounds errors. I tried with a smaller run and
> > > >> didn't see the error.
> > > >> This run was using beagle, pads, and communicado. I was also using
> > > >> cdm. I will post the log in a bit. I am seeing if I cam replicate it
> > > >> without using cdm and with a smaller site pool.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110820/2fff126e/attachment.html>
