[Swift-devel] provider staging question
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Aug 16 20:15:54 CDT 2011
Hi Jon,
I'll try a short answer, but this needs more thoight, and much testing:
- Dont use CDM with provider staging (yet; maybe someday that will make sense...)
I dont tthink the two will work together well.
- ps should stage to the local hard disk; I *think* it may honor the workdirectory tag as where to stage, though. Or maybe the scratch tag?  I think it defaults to /tmp.  This needs to be tested and documented. Mihael, can you clarify?
Miek
----- Original Message -----
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Sent: Tuesday, August 16, 2011 6:08:47 PM
> Subject: provider staging question
> Mike,
> I am configuring the run to test the SwiftMontage runs with provider
> staging turned on as you suggested. When I turn on provider staging
> should I not use CDM? The issue that I was experiencing that led me to
> start using CDM was extremely long copy times from the cwd to the job
> directory specified by the <workdirectory> in the sites.xml file. Does
> provider staging circumvent that issue? I know provider staging copies
> the input files directly onto the compute nodes local disk but that is
> about all I know. Could you fill me in a bit on what exactly provider
> staging does? Would using both CDM "direct" directives and provider
> staging cause some degraded performance?
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
