[Swift-devel] Cogkit SVN access
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 11 17:13:37 CDT 2011
I don't have access to BG/P but I know on Beagle there was an issue with the IBMs Java. It was throwing an EOFException and you needed to install Suns jre. Ketan reported this awhile back and I experienced the issue as well. I do not know if this problem has been resolved though.
----- Reply message -----
Date: Thu, Aug 11, 2011 4:06 pm
Subject: [Swift-devel] Cogkit SVN access
To: "David Kelly" <davidk at ci.uchicago.edu>
Cc: <swift-devel at ci.uchicago.edu>
Putting this in the release notes is a good idea.  The BG/P and Cray both
have 1.6.
 	Justin
On Thu, 11 Aug 2011, David Kelly wrote:
> Thanks Mihael.
> I think there are a few systems still out there running 1.5, but not
> many. Intrepid runs 1.5 by default, but I think you can modify it with
> softenv. There was another machine called sisboombah that only had 1.5.
> I don't have any strong feelings about it one way or another, but it's a
> probably a good idea to come up with a list of what is supported
> (version, IBM java, openjdk?) and add it to the list of things we test
> before a new release.
> David
>> From: "Mihael Hategan" <hategan at mcs.anl.gov>
>> Cc: swift-devel at ci.uchicago.edu
>> Sent: Thursday, August 11, 2011 1:54:12 PM
>> Subject: Re: [Swift-devel] Cogkit SVN access
>> I gave you access to the cog svn, but the question is whether we still
>> care about java 1.5. Are there any machines that haven't moved to 1.6?
>> On the other hand, it could be argued that the cost of keeping 1.5
>> compatibility is relatively low, so we might as well just do it.
>> On Thu, 2011-08-11 at 12:45 -0500, David Kelly wrote:
>>> Hello,
>>> How can I request access to the cogkit SVN repo? I have a patch I'd
>>> like to apply that allows 0.93 to compile under Java 1.5. My
>>> sourceforge username is davidkelly999.
>>> Thanks,
>>> David
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110811/a04969e2/attachment.html>
