[Swift-devel] Cogkit SVN access
    David Kelly
    davidk at ci.uchicago.edu
    Thu Aug 11 14:25:55 CDT 2011
Thanks Mihael.
I think there are a few systems still out there running 1.5, but not many. Intrepid runs 1.5 by default, but I think you can modify it with softenv. There was another machine called sisboombah that only had 1.5. I don't have any strong feelings about it one way or another, but it's a probably a good idea to come up with a list of what is supported (version, IBM java, openjdk?) and add it to the list of things we test before a new release.
David
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: swift-devel at ci.uchicago.edu
> Sent: Thursday, August 11, 2011 1:54:12 PM
> Subject: Re: [Swift-devel] Cogkit SVN access
> I gave you access to the cog svn, but the question is whether we still
> care about java 1.5. Are there any machines that haven't moved to 1.6?
> On the other hand, it could be argued that the cost of keeping 1.5
> compatibility is relatively low, so we might as well just do it.
> On Thu, 2011-08-11 at 12:45 -0500, David Kelly wrote:
> > Hello,
> > How can I request access to the cogkit SVN repo? I have a patch I'd
> > like to apply that allows 0.93 to compile under Java 1.5. My
> > sourceforge username is davidkelly999.
> > Thanks,
> > David
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
