[Swift-devel] ssh test case on pads/beagle
    Jonathan Monette
    jonmon at mcs.anl.gov
    Wed Aug 10 19:09:03 CDT 2011
Exit code "127" normally means that a particular function doesn't exist.  Are you sure that all those paths to apps exist?
Also, I am not sure if this is a problem but shouldn't there be a third column in the app file?  LIke
"ssh		echo	/bin/echo	null		null		null"
On Aug 10, 2011, at 6:41 PM, Alberto Chavez wrote:
> I changed my ssh-key, and they worked on the MCS machines because the authorized_keys file has not been updated yet on the CI Machines.
> I created a new ssh-key using:
> ssh-keygen -t rsa -b 2048
> exactly as the MCS site suggested,
> On the other hand, I still have a problem, I am getting the following error:
> Swift svn swift-r4978 cog-r3226
> RunID: 20110810-1819-1cdo2o62
> Progress:  time: Wed, 10 Aug 2011 18:19:42 -0500
> Exception in cat:
> Arguments: [data.txt]
> Host: ssh
> Directory: 001-catsn-ssh-20110810-1819-1cdo2o62/jobs/9/cat-9jd0g9ek
> Caused by: null
> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 127
> Final status:  time: Wed, 10 Aug 2011 18:20:00 -0500  Failed:10
> The following errors have occurred:
> 1. Job failed with an exit code of 127 (10 times)
> These are the contents of the log:
> Execution completed with errors
> 2011-08-10 18:19:43,251-0500 INFO  ConnectionProtocol Freeing channel 0 [Unnamed Channel]
> 2011-08-10 18:19:43,263-0500 INFO  Exec Exit code 127
> 2011-08-10 18:19:43,269-0500 INFO  ConnectionProtocol Freeing channel 0 [Unnamed Channel]
> 2011-08-10 18:19:43,277-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION jobid=cat-9jd0g9ek - Application exception: null
> 2011-08-10 18:19:43,280-0500 INFO  vdl:execute END_FAILURE thread=0-5-3-1 tr=cat
> 2011-08-10 18:19:43,281-0500 INFO  vdl:execute Exception in cat:
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:250)
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:254)
>         at org.globus.cog.karajan.workflow.nodes.GenerateErrorNode.post(GenerateErrorNode.java:27)
>         at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
>         at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>         at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
>         at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
>         at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
>         at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
>         at org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
>         at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
>         at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
>         at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
>         at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
>         at java.util.concurrent.FutureTask.run(FutureTask.java:166)
>         at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
>         at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
>         at java.lang.Thread.run(Thread.java:636)
> 2011-08-10 18:20:00,332-0500 INFO  ExecutionContext Detailed exception:
> I believe that the problem resides on the TC file because when I run a much simpler SwiftScript like:
> int i = 9;
> trace(i);
> I get the following output:
> swift traceme.swift -tc.file tc.template.data -sites.file sites.template.xml -config cf
> RunID: 20110810-1832-buktjj3d
> Progress:  time: Wed, 10 Aug 2011 18:32:30 -0500
> SwiftScript trace: 9.0
> Final status:  time: Wed, 10 Aug  2011 18:32:30 -0500
> but as soon as I start using the commands stated the TC file, I get the "exit code 127"
> My tc file reads:
> ssh     cat             /bin/cat        null    null
> ssh     ls              /bin/ls         null    null
> ssh     grep            /bin/grep       null    null
> ssh     sort            /bin/sort       null    null
> ssh     paste           /bin/paste      null    null
> ssh     wc              /usr/bin/wc     null    null
> I am working on the login node of the MCS machine trying to ssh via Swift to steamroller.
> > Subject: Re: [Swift-devel] ssh test case on pads/beagle
> > From: hategan at mcs.anl.gov
> > To: alberto_chavez at live.com
> > CC: swift-devel at ci.uchicago.edu
> > Date: Tue, 9 Aug 2011 11:57:06 -0700
> > Hmm: Unsupported passphrase algorithm: AES-128-CBC
> > I'll try to see how that can be fixed. In the mean time, can you
> > generate a new key pair with 3DES encryption instead and use that?
> > On Tue, 2011-08-09 at 13:43 -0500, Alberto Chavez wrote:
> > > Hello,
> > > I am trying to run a simpler case than ssh-pbs-coaster test case, and
> > > I'm still having the same error.
> > > Now I am running only ssh test case
> > > (/tests/providers/ssh/001-catsn-ssn.swift)
> > > The command line is:
> > > swift -config cf -tc.file tc.template.data -sites.file
> > > sites.template.xml 001-catsn-ssh.swift
> > > The output:
> > > Swift svn swift-r4861 (swift modified locally) cog-r3183
> > > RunID: 20110809-1336-ohte788a
> > > Progress: time: Tue, 09 Aug 2011 13:36:42 -0500
> > > Exception in cat:
> > > Host: ssh
> > > Directory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/m/cat-mq74h7ek
> > > Caused by: null
> > > Caused by:
> > > org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Invalid private key or passphrase
> > > Caused by:
> > > com.sshtools.j2ssh.transport.publickey.InvalidSshKeyException: Can't
> > > read key due to cryptography problems:
> > > java.security.NoSuchAlgorithmException: Unsupported passphrase
> > > Progress: time: Tue, 09 Aug 2011 13:36:43 -0500 Selecting site:8
> > > Submitting:1 Failed:1
> > > Exception in cat:
> > > Host: ssh
> > > Directory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/n/cat-nq74h7ek
> > > Caused by: null
> > > Caused by:
> > > Caused by:
> > > Progress: time: Tue, 09 Aug 2011 13:36:44 -0500 Selecting site:7
> > > Submitting:1 Failed:2
> > > Exception in cat:
> > > Host: ssh
> > > Directory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/o/cat-oq74h7ek
> > > Caused by: null
> > > Caused by:
> > > Caused by:
> > > "error_log.log" 105L, 5770C
> > > My auth.defaults reads:
> > > login1.beagle.ci.uchicago.edu.type=key
> > > login1.beagle.ci.uchicago.edu.username=achavez
> > > login1.beagle.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
> > > login1.pads.ci.uchicago.edu.type=key
> > > login1.pads.ci.uchicago.edu.username=achavez
> > > login1.pads.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
> > > and it has been set to 600, I ommited the passphrase line, but it is
> > > there, and the passphrase is right because I just verified it in two
> > > ways:
> > > 1) by logging to pads and beagle without providing a password
> > > 2) "changed" the password. I the "new" password is the same as the
> > > "old" one.
> > > sites.templates.xml:
> > > <config>
> > > <pool handle="ssh">
> > > <execution provider="ssh" url="login1.pads.ci.uchicago.edu"
> > > jobmanager="ssh"/>
> > > <filesystem provider="ssh" url="login1.pads.ci.uchicago.edu" />
> > > <profile key="jobThrottle" namespace="karajan">0</profile>
> > > <workdirectory>/home/achavez/swiftwork</workdirectory>
> > > </pool>
> > > </config>
> > > config file:
> > > wrapperlog.always.transfer=true
> > > sitedir.keep=true
> > > execution.retries=0
> > > lazy.errors=true
> > > status.mode=provider
> > > use.provider.staging=true
> > > provider.staging.pin.swiftfiles=false
> > > foreach.max.threads=10
> > > provenance.log=true
> > > I also tried a simpler SwiftScript:
> > > type filemsg;
> > > app (filemsg output) hello(string s)
> > > echo s stdout=@filename(output);
> > > filemsg myfile<"dogcatdinosaur.out">;
> > > myfile = hello("dog,cat,dinosaur");
> > > and I get the following output:
> > > RunID: 20110809-1343-2es2hel2
> > > Progress: time: Tue, 09 Aug 2011 13:43:25 -0500
> > > Exception in echo:
> > > Arguments: [dog,cat,dinosaur]
> > > Host: ssh
> > > Directory: hello_swift-20110809-1343-2es2hel2/jobs/0/echo-0oldh7ek
> > > Caused by: null
> > > Caused by:
> > > Caused by:
> > > Final status: time: Tue, 09 Aug 2011 13:43:26 -0500 Failed:1
> > > 1. Can't read key due to cryptography problems:
> > > any thoughts on this?
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110810/7c9e06b3/attachment.html>
