[Swift-devel] Persistent coasters running one job per worker
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Tue Aug  9 14:09:07 CDT 2011
I do not see any recent log in ~/.globus/coasters. The stdout/err of the
coaster service run is in the attached service.log and the coaster.log is in
the attached swift.log.
On Tue, Aug 9, 2011 at 1:59 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> but but but I checked this, and it worked fine...
> Can you also post the coasters log (on the machine the coaster service
> is on, in ~/.globus/coasters)?
> On Tue, 2011-08-09 at 13:47 -0500, Ketan Maheshwari wrote:
> > Mihael,
> > I was discussing this with Justin and we thought you could help:
> > I am observing that persistent coasters are running one job per worker
> > as opposed to the number specified in jobspernode (I also tried
> > nodegranularity) on sites.xml.
> > Attaching the log, and the sites.xml for the run. Swift is 0.93 (Swift
> > svn swift-r4968 cog-r3225).
> > The script is Mike's catsnsleep that sleeps for 20s with n=10.
> > Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110809/96dfe0db/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110809/96dfe0db/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110809/96dfe0db/attachment-0001.obj>
