[Swift-devel] ssh test case on pads/beagle
Alberto Chavez
alberto_chavez at live.com
Tue Aug 9 13:43:59 CDT 2011
Hello,
I am trying to run a simpler case than ssh-pbs-coaster test case, and I'm still having the same error.Now I am running only ssh test case (/tests/providers/ssh/001-catsn-ssn.swift)
The command line is:swift -config cf -tc.file tc.template.data -sites.file sites.template.xml 001-catsn-ssh.swift
The output:Swift svn swift-r4861 (swift modified locally) cog-r3183
RunID: 20110809-1336-ohte788aProgress: time: Tue, 09 Aug 2011 13:36:42 -0500Exception in cat:Arguments: [data.txt]Host: sshDirectory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/m/cat-mq74h7ek- - -
Caused by: nullCaused by: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Invalid private key or passphraseCaused by: com.sshtools.j2ssh.transport.publickey.InvalidSshKeyException: Can't read key due to cryptography problems: java.security.NoSuchAlgorithmException: Unsupported passphrase algorithm: AES-128-CBCProgress: time: Tue, 09 Aug 2011 13:36:43 -0500 Selecting site:8 Submitting:1 Failed:1Exception in cat:Arguments: [data.txt]Host: sshDirectory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/n/cat-nq74h7ek- - -
Caused by: nullCaused by: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Invalid private key or passphraseCaused by: com.sshtools.j2ssh.transport.publickey.InvalidSshKeyException: Can't read key due to cryptography problems: java.security.NoSuchAlgorithmException: Unsupported passphrase algorithm: AES-128-CBCProgress: time: Tue, 09 Aug 2011 13:36:44 -0500 Selecting site:7 Submitting:1 Failed:2Exception in cat:Arguments: [data.txt]Host: sshDirectory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/o/cat-oq74h7ek- - -
Caused by: nullCaused by: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Invalid private key or passphraseCaused by: com.sshtools.j2ssh.transport.publickey.InvalidSshKeyException: Can't read key due to cryptography problems: java.security.NoSuchAlgorithmException: Unsupported passphrase algorithm: AES-128-CBC"error_log.log" 105L, 5770C
My auth.defaults reads:
login1.beagle.ci.uchicago.edu.type=key login1.beagle.ci.uchicago.edu.username=achavez login1.beagle.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
login1.pads.ci.uchicago.edu.type=key login1.pads.ci.uchicago.edu.username=achavez login1.pads.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
and it has been set to 600, I ommited the passphrase line, but it is there, and the passphrase is right because I just verified it in two ways:
1) by logging to pads and beagle without providing a password
2) "changed" the password. I the "new" password is the same as the "old" one.
sites.templates.xml:
<config><pool handle="ssh"> <execution provider="ssh" url="login1.pads.ci.uchicago.edu" jobmanager="ssh"/> <filesystem provider="ssh" url="login1.pads.ci.uchicago.edu" /> <profile key="jobThrottle" namespace="karajan">0</profile> <workdirectory>/home/achavez/swiftwork</workdirectory></pool></config>
config file:
wrapperlog.always.transfer=truesitedir.keep=trueexecution.retries=0lazy.errors=truestatus.mode=provideruse.provider.staging=trueprovider.staging.pin.swiftfiles=falseforeach.max.threads=10provenance.log=true
I also tried a simpler SwiftScript:
type filemsg;
app (filemsg output) hello(string s){ echo s stdout=@filename(output);}
filemsg myfile<"dogcatdinosaur.out">;myfile = hello("dog,cat,dinosaur");
and I get the following output:
RunID: 20110809-1343-2es2hel2Progress: time: Tue, 09 Aug 2011 13:43:25 -0500Exception in echo:Arguments: [dog,cat,dinosaur]Host: sshDirectory: hello_swift-20110809-1343-2es2hel2/jobs/0/echo-0oldh7ek- - -
Caused by: nullCaused by: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Invalid private key or passphraseCaused by: com.sshtools.j2ssh.transport.publickey.InvalidSshKeyException: Can't read key due to cryptography problems: java.security.NoSuchAlgorithmException: Unsupported passphrase algorithm: AES-128-CBCFinal status: time: Tue, 09 Aug 2011 13:43:26 -0500 Failed:1The following errors have occurred:1. Can't read key due to cryptography problems: java.security.NoSuchAlgorithmException: Unsupported passphrase algorithm: AES-128-CBC
any thoughts on this?
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110809/8a8c5e44/attachment.html>
