[Swift-devel] ssh-pbs-coasters test case on PADS.
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Aug  8 19:31:52 CDT 2011
On Mon, 2011-08-08 at 19:08 -0500, Ketan Maheshwari wrote:
> Alberto,
> Create an auth.defaults file in your ~/.ssh directory.
> Add contents of the following form:
> bridled.ci.uchicago.edu.type=key
> bridled.ci.uchicago.edu.username=urusername
> bridled.ci.uchicago.edu.key=/path/to/your/id_rsa
> bridled.ci.uchicago.edu.passphrase=yourpassphrase
RIght. If you feel that having your passphrase there is not ok, you can
omit it, but you will get a prompt for it.
I think you should only get the prompt once, but I've seen it pop twice
in the same run, so I'm going to check that.
