[Swift-devel] Can't build latest 0.93
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Aug  7 01:57:40 CDT 2011
Try now (cog r3215)
On Sun, 2011-08-07 at 00:54 -0500, David Kelly wrote:
> I am getting this error while running ant dist on 0.93:
> package.list:
>      [echo] [provider-coaster]: PACKAGE LIST
>      [java] Missing package: backport-util-concurrent.jar
> BUILD FAILED
> /home/david/cog.093/modules/swift/build.xml:73: The following error occurred while executing this line:
> /home/david/cog.093/mbuild.xml:445: The following error occurred while executing this line:
> /home/david/cog.093/mbuild.xml:79: The following error occurred while executing this line:
> /home/david/cog.093/mbuild.xml:52: The following error occurred while executing this line:
> /home/david/cog.093/modules/swift/dependencies.xml:13: The following error occurred while executing this line:
> /home/david/cog.093/mbuild.xml:163: The following error occurred while executing this line:
> /home/david/cog.093/mbuild.xml:168: The following error occurred while executing this line:
> /home/david/cog.093/modules/provider-coaster/build.xml:60: The following error occurred while executing this line:
> /home/david/cog.093/modules/provider-coaster/build.xml:168: Java returned: 1
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
