[Swift-devel] Try Ranger with nodeGranularity=16
    Jonathan Monette
    jonmon at mcs.anl.gov
    Fri Aug  5 09:42:13 CDT 2011
I will certainly give this a try.
I think we mentioned this in the con call on Wednesday but could someone post the svn co procedure for 0.93 perhaps to the swift-devel google site?  The swift 0.93 branch is easy to figure out but cog not so much.
On Aug 5, 2011, at 9:25 AM, Michael Wilde wrote:
> I learned from Mihael yesterday that the SGE provider should in fact work on Ranger in 0.93 and trunk if you set nodeGranularity to 16.
> This is a confusion between nodes and cores that should get fixed in 0.94 unless testing indicates that the above setting doesnt work in 0.93.
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
