[Swift-devel] ssh:pbs to beagle
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Apr 28 12:20:57 CDT 2011
On Thu, 2011-04-28 at 10:14 -0500, Ketan Maheshwari wrote:
> Hello,
> Some context:
> I am trying to submit a big run on Beagle using swift + coasters.
> However, a previous run is already underway on beagle. So, there are
> two difficulties running a new run from its login node:
> 1. Running another swift from the same jvm will result in chaos on the
> logs (As far as I know, please correct me if this is not the case
> anymore)
Maybe, but I must ask, how would you get another swift instance in the
same JVM as the first one?
> 2. Login node is already under load because of my running previous big run.
Shouldn't be under that much load, but that is something you can
actually measure.
Mihael
