[Swift-devel] Website documentation
    David Kelly
    dk0966 at cs.ship.edu
    Mon Apr 25 21:43:32 CDT 2011
To get that working, I downloaded and installed GNU source-highlight. It was
kind of a pain because to get compiled because it didn't work with the
default boost libraries. Feel free to copy it from ~davidk/source-highlight.
I set the code style to Java.. and for the most part that seems to work
reasonably well on swiftscript code. At some point I should create an actual
language definition file for Swift.
David
On Mon, Apr 25, 2011 at 10:24 PM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> David,
> How did you get the java-like source highlighting working in Swift code? I
> was trying similar syntax but getting this error on asciidoc compile:
> filter non-zero exit code: source-highlight -f xhtml -s java: returned 127
> Ketan
> On Apr 25, 2011, at 9:09 PM, David Kelly wrote:
> Hello,
> I created a first draft of the Swift tutorial in asciidoc. Here are the
> documents it created:
> HTML: http://www.ci.uchicago.edu/~davidk/tutorial.html
> PDF: http://www.ci.uchicago.edu/~davidk/tutorial.pdf
> ASCIIDOC: http://www.ci.uchicago.edu/~davidk/tutorial.txt
> There are still a few things I need to tweak, but overall I'm finding
> asciidoc pretty nice to work with.
> The ticket that was created for this, 375, mentions that these documents
> should be created during ant dist. But I think most people do not have
> asciidoc installed by default, and including it with Swift will not be
> possible due to GPL licensing issues. Asciidoc itself is GPL, as well as the
> various packages it depends on - source-highlight for code highlighting, and
> dblatex for generating PDFs.
> I think Justin's suggestion of keeping document generation limited to a CI
> machine is the way to go. If that makes sense to you all, I will start on a
> script to generate the documents, and continue working on manually
> converting the rest of the documentation material into asciidoc format.
> David
> On Sat, Apr 23, 2011 at 1:00 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>> Yeah- I am trying to be more careful with umask.  Please send me your
>> error message and I will modify the chmods in the script accordingly.
>> For the new structure, I recommend that we stop using svn to move the
>> content and just push the simple documents.  I would be fine with a cp-based
>> method that only works from a CI system.
>> On Sat, 23 Apr 2011, Michael Wilde wrote:
>>  Looking deeper into this, I see that the permissions in /ci
>>> /www/projects/swift do not permit anyone in vdl2-svn to do svn-update and to
>>> run update.sh completely for the entire doc set.
>>> Justin, I think this occurred when you last worked on this directory. Can
>>> you see if update.sh works for you at the moment? That should push David's
>>> committed tutorial corrections to the live content.
>>> I suggest that rather than correct this, we push ahead updating the
>>> entire per-release doc set to asciidoc and then adjust update.sh and the
>>> /ci/www/projects/swift directory to match it. David, can you do this under
>>> bug 375, and propose the new structure with a README that outlines how all
>>> the directories and content-push scripts will be organized?
>>> Thanks,
>>> Mike
>>> ----- Original Message -----
>>> David, you're not in the vdl2-svn UNIX group, which you need in order to
>>> run this. I'll request that you be added, and do an svn-co of the tutorial
>>> and run update.sh for you in the meantime.
>>> - Mike
>>> Hello,
>>> What is the current process for updating website documentation? I believe
>>> the MaintainingSwiftWebContent wiki may be out of date.
>>> I am trying to submit some corrections to the Swift tutorial. Previously
>>> I could modify it through www/ in SVN. Now I believe it is generated from
>>> swift/docs/tutorial.xml for each release. Is this correct? Is there still a
>>> cron job that runs daily and updates the site? I am not seeing the changes I
>>> made yesterday reflected on the website. Do I need to manually run
>>> /ci/www/projects/swift/update.sh? I do not have permissions to read or
>>> execute it at the moment.
>>> Thanks,
>>> David
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110425/ca40f30f/attachment.html>
