[Swift-devel] provider staging vdl-int.staging.k doesn't honor	wrapperlog.transfer.always
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Apr 15 20:17:20 CDT 2011
I've committed a fix. Justin's patch I think was partially solving the
problem. The original semantics of this parameter was to always transfer
the info file in the event of an application error, but not necessarily
so when the application invocation succeeded.
There was no easy fix. It required adding some staging "modes" (i.e.
transfer only in case of error and/or only if file exists). Not all
providers support this (only local and coaster), but then not all
providers support staging to begin with.
This is now in. See
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=295.
Mihael
On Mon, 2011-01-17 at 14:49 -0600, Justin M Wozniak wrote:
> Try the attached patch- I will test it a bit more before committing.
> Thanks for the report.
>  	Justin
> On Mon, 17 Jan 2011, Allan Espinosa wrote:
> > vdl-int.staging.k line 239
> > There's no check for the swift config property.  hence i'm
> > alwaysgetting the wrapper logs in provider staging.
> > -Allanb
> Justin M Wozniak
> _______________________________________________ Swift-devel mailing list Swift-devel at ci.uchicago.edu http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
