[Swift-devel] CCA-11 Swift Poster Visitor's  Questions
    Ian Foster
    foster at anl.gov
    Wed Apr 13 05:44:03 CDT 2011
I assume that there was some thought behind the question. E.g., they might think that a lot of work and code is required to wrap the executables (which is not the case). Or that a lot of work is required to configure the coasters. Or something else?
On Apr 13, 2011, at 5:41 AM, Daniel S. Katz wrote:
> On Apr 13, 2011, at 5:30 AM, Ian Foster wrote:
>> Hi Ketan:
>> Nice work transcribing the questions!
>> I'm curious as to what the "deceptive" question means. The simplicity doesn''t seem deceptive to me!
> I don't think deceptive was used seriously.
>> The poster title is a bit deceptive: it makes this sound like a research poster, when the content reads more like a Swift advertisement. It would be good to produce a paper that provides a detailed description of the coaster's mechanism, a comparison with other work in this area, and a careful evaluation of the functioning of the coaster implementation.
> A few of us have started this, but haven't gotten very far yet.
>> Ian.
>> On Apr 13, 2011, at 12:00 AM, Ketan Maheshwari wrote:
>>> Here is a list of questions asked by the visitors of our swift poster at the CCA-11 poster session [poster attached here] earlier this evening:
>>> -- What is the novelty in this stuff? Meta-scheduling has been done in the past; scalability studies have also been done in the past (by Swift too).
>>> -- Is this similar to map/reduce?
>>> -- Are you planning to compare Swift/coasters with map/reduce?
>>> -- What do people do without Swift in this same scenario (multi-clouds)?
>>> -- This looks similar to Condor glide-ins!?
>>> -- (After explaining the coasters mechanism) What is sites script again? (some more explaining that it is not script it is a descriptor) And again what is that sites file?
>>> -- What happens without Coasters?
>>> -- What do I need to run Swift on my cluster?
>>> -- Would it benefit me if I chuck Python and use Swift instead for my GIS related app?
>>> -- The simplicity of script-code seems deceptive!?!
>>> -- Is the coasters scheduling algorithm published somewhere?
>>> <SwiftPoster.CCA-11.pdf>
>>> --Ketan
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Daniel S. Katz
> University of Chicago
> (773) 834-7186 (voice)
> (773) 834-3700 (fax)
> d.katz at ieee.org or dsk at ci.uchicago.edu
> http://www.ci.uchicago.edu/~dsk/
