[Swift-devel] error in 0.92 source
Jonathan Monette
jon.monette at gmail.com
Tue Apr 12 10:03:51 CDT 2011
No. It was the same. As I was digging deeper into the problem I started
remembering that all this seemed familiar. I checked my properties file and
accidentally deleted the wrapper.parameter.mode line. I wanted to confirm
this was the problem before I reported back and it just took awhile before
the workflow got to that section.
That error makes sense once I remembered what was wrong. This might be
another place where a better error message(not just the one linux reported
back) would have probably helped shed light on what is going on, imho.
On Tue, Apr 12, 2011 at 6:10 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Jon, the error is "Argument list too long" (E2BIG) - most likely because
> you are trying to form an argument list to an app that is longer than the
> Linux limit (which is host-specific and settable during Linux configuration,
> *I think*).
> As I was writing this response, I realized you already dealt with this
> issue in a thread on swift-user in Oct 2010 (subject "Argument list too
> long"). Is your current problem some new manifestation of the prior argument
> passing problem?
> I also realized that I dont understand the interaction between property
> "wrapper.parameter.mode" and the need to use writeData() to form argument
> lists, and that this needs to be explained in a Cookbook -> User Guide
> section.
> So before I go deeper into this, can you explain if the current problem is
> different than the prior one?
> Thanks,
> - Mike
> This page has some useful info on the limit:
> http://www.in-ulm.de/~mascheck/various/argmax/
> On communicado the limit seems to be some percentage of the stack size,
> which defaults to 10M. The article above says that Linux 2.26 and above use
> .25 * stack size.
> Where are you running, and what is the likely command line length of your
> largest app invocations? (Keep in mind that pathnames may be longer than you
> expect and that Swift is running _swiftwrap which also has specific arg
> passing conventions).
> This is often an issue when you call a summarization app, and try to pass
> it all the files processed in some large prior foreach loop.
> Ben added some support for passing much longer argument lists in a file via
> the function writeData, and there is also this property:
> # Controls how swift will supply parameters to the remote wrapper script.
> # 'args' mode will pass parameters on the command line
> # 'files' mode will pass parameters through an additional input file
> # valid values: args, files
> # Default: files
> # wrapper.parameter.mode=args
> > Does anyone know what is this error trying to tell me?
> > Caused by: Cannot run program "/bin/bash" (in directory
> "/gpfs/pads/swift/jonmon/Swift/work/localhost/rectified-20110411-1923-pqygyay7"):
> > java.io.IOException: error=7, Argument list too long
> > Caused by: java.io.IOException: Cannot run program "/bin/bash" (in
> > directory
> > Any intelligent fool can make things bigger and more complex... It
> > takes a touch of genius - and a lot of courage to move in the opposite
> > direction.
> > - Albert Einstein
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110412/28f42070/attachment.html>
