[Swift-devel] [Bug 319] New: Set logging level via swift.properties to a few pre-defined levels
    bugzilla-daemon at mcs.anl.gov
    Mon Apr  4 22:21:12 CDT 2011
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=319
           Summary: Set logging level via swift.properties to a few
                    pre-defined levels
           Product: Swift
           Version: 0.93
          Platform: All
        OS/Version: All
            Status: NEW
          Severity: normal
          Priority: P2
         Component: Log processing and plotting
        AssignedTo: wozniak at mcs.anl.gov
        ReportedBy: wilde at mcs.anl.gov
Implement log properties of fast, info, normal, debug, trace (or similar, much
like coaster worker.pl)
fast - very light logging, for performance research
info - lighter than normal logging
normal - a log level that doesnt degrade performance much, tells the user
everything they need, and is sufficient to drive all features including
provenance, Text User Interface (-tui option) and performance plotting
- debug - supports most debugging needed
- trace - for only the most detailed level of debugging
The current log4j control mechanism should be used only for fine grained
developer control.
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the reporter.
