[Swift-devel] Fwd: [Swift-user] determining unmapped paths
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Sat Apr  2 16:41:15 CDT 2011
Filed as bug 315: https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=315
2011/3/24 Michael Wilde <wilde at mcs.anl.gov>:
> Sarah, this is a perfect example of a messaging deficiency to fix. Can you add to bugzilla?
> Thanks,
> Mike
> ----- Forwarded Message -----
> From: "Allan Espinosa" <aespinosa at cs.uchicago.edu>
> To: "Swift-User" <swift-user at ci.uchicago.edu>
> Sent: Thursday, March 24, 2011 4:28:51 PM
> Subject: [Swift-user] determining unmapped paths
> I'm trying figure out where in my workflow is causing this problem:
> 2011-03-24 16:23:50,485-0500 WARN  FlowNode Ex098
> java.lang.IllegalStateException: mapper.existing() returned a path [3]
> that it cannot subsequently map
>        at org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:129)
>        at org.griphyn.vdl.mapping.RootArrayDataNode.checkInputs(RootArrayDataNode.java:67)
>        at org.griphyn.vdl.mapping.RootArrayDataNode.innerInit(RootArrayDataNode.java:53)
>        at org.griphyn.vdl.mapping.RootArrayDataNode.handleClosed(RootArrayDataNode.java:80)
>        at org.griphyn.vdl.mapping.AbstractDataNode.notifyListeners(AbstractDataNode.java:583)
>        at org.griphyn.vdl.mapping.AbstractDataNode.closeShallow(AbstractDataNode.java:396)
>        at org.griphyn.vdl.mapping.ArrayDataNode.closeDeep(ArrayDataNode.java:51)
>        at org.griphyn.vdl.karajan.lib.PartialCloseDataset.function(PartialCloseDataset.java:79)
>        at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:68)
>        at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
>        at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
>        at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>        at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
>        at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
>        at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
>        at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
>        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>        at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>        at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>        at java.lang.Thread.run(Thread.java:619)
> It doesn't specify which data object it crashes on so i'm quite
> clueless at this point.
> I'm using the latest trunk
> any particular log4j class i should be enabling to debug?
> Thanks,
> -Allan
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
