[Swift-devel] [Bug 315] New: better diagnostics to identify unmapped paths
bugzilla-daemon at mcs.anl.gov
Sat Apr 2 16:38:39 CDT 2011
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=315
Summary: better diagnostics to identify unmapped paths
Product: Swift
Version: unspecified
Platform: PC
OS/Version: Linux
Status: NEW
Severity: normal
Priority: P2
Component: SwiftScript language
AssignedTo: hategan at mcs.anl.gov
ReportedBy: aespinosa at cs.uchicago.edu
This works
$ cat seq.in
1
2
3
4
$ cat array_incomplete.swift
type file;
app(file o[])
split(file i, int j){
split "-l" 1 @filename(i) @strcat(j, "seqout.");
file input <"seq.in">;
foreach j in [0:1] {
string foo;
if (j == 0) {
foo = "0seqout.aa, 0seqout.ab, 0seqout.ac, 0seqout.ad";
if (j == 1) {
foo = "1seqout.aa, 1seqout.ab, 1seqout.ac, 1seqout.ad";
file out[] <fixed_array_mapper; files=foo>;
if (j < 1) {
out = split(input, j); // line 21
else {
out = split(input, j); // line 23
$$ ~/swift/swift-0.92/bin/swift -tc.file tc.data array_incomplete.swift
Swift svn swift-r4157 cog-r3056
RunID: 20110402-1619-dn042ure
Progress:
Progress: Stage in:1 Finished successfully:1
Final status: Finished successfully:2
But if I comment out line 21, we get this error message:
RunID: 20110402-1621-k63e22s2
Progress:
Execution failed:
mapper.existing() returned a path [0] that it cannot subsequently map
The swift log file contains this corresponding entry:
011-04-02 16:21:13,887-0500 DEBUG VDL2ExecutionContext vdl:setfieldvalue @
array_incomplete.kml, line: 155: java.lang.IllegalStateException:
Checking the kml file we have this call to setFieldValue():
array_incomplete.kml:155
<sequentialWithID>
<sequential>
<vdl:setfieldvalue>
<argument name="var">
<variable>foo</variable>
</argument>
<argument name="value">
<variable>swift#string#17003</varia ble>
</argument>
</vdl:setfieldvalue>
</sequential>
</sequentialWithID>
Mike and I concluded that the reason for the error was that out[] is already
recognized as an output dataset in line 23. But for j=0, out[] as an output
file was not produced and will result in unmapped paths.
Is there a better way to diagnose this problem off the bat? Or is this the
expected behavior? Can out[] be an input file (non-intermediate) for j=0 and
output file for j=1?
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the assignee of the bug.
