[Swift-devel] Re: saturday morning rambling about exceptions
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Sat Apr  2 09:38:50 CDT 2011
Yeah, I like the simplicity of if(!exists(...)).
With try/catch I just think it would be difficult for the user to reason
about what state things are in when an exception occurs and we end up in the
catch block - it seems very nondeterministic which threads will be running
and how much progress they will have made
- tim
On Fri, Apr 1, 2011 at 11:34 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> > Try/catch statements don't have a clean intepretation if you're trying to
> > follow the flow of data through the program.
> Right.
> I thought about this a bit before but it started getting all haskelly and
> something i didn't want to approach - as mike says its much more
> researchy.
> The main idea which I found most comfortable was Haskell's Either type.
> That can model something like exceptions but is more amenable to a
> dataflow style of programming.
> (although C implements something very restricted similar in the form of
> pointers which can be NULL, or when returning a return code that is in
> some range of values for an error and some other range of values for
> success)
> The way the haskell Either type works is that something which might "throw
> an exception" returns a value that is either an error object or a correct
> value object.
> So then you use an if or a case or anything else that can change behaviour
> based on data to change your flow.
> Imagine in C:
>   p = malloc(5);
>   if(p == NULL) {
>       /* catch-exception, but dataflow style - we don't have to look at p
>          right after the malloc. We can store it into a structure and
>          come back to it later to check.
>          unfortuantely, there is not enough space in p to represent
>          any richer kind of exception information other than "FAIL" */
>   } else {
>       /* no exception, and we have the correct value in p */
> In haskell, that looks like:
>     p = somefunc
>     case p of
>        Right d -> doSomethingWith d   -- somefunc succeeded and returned
>                                       -- us value d
>        Left ex -> handleError ex      -- somefunc failed and returned
>                                       -- value ex as the equivalnet of a
>                                       -- Java Exception object.
> Now it gets a bit awkward having to unwrap "Right d" after every such
> function call, and in that respect I think a syntax that looks more like
> try-catch is much easier to program with. However I think the right way to
> go is to define its semantics in terms of "dataflow" style exceptions
> above rather than control-flow.
> I think that's possible and would result in something that satisfies both
> the dataflow-purist camp and the "I like exception syntax" camp (both
> camps of which I'm in ;)
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110402/a138525d/attachment.html>
