[Swift-devel] [Bug 291] New: Add a exists() function to test	for	file existence
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Apr  1 13:25:02 CDT 2011
John, I cc'ed you to confirm that the function is exactly what you were looking for, and that the simple code below matches exactly the requirement thats driving this feature request.
Can you confirm that both of these are true?
We just want to make sure that we understand the need and determine if the proposed exists() function is the best way to address it. From your comment below, I was not quite sure if exists() is exactly the right approach here.
Mike
----- Original Message -----
> Michael,
> This type of function would be great to have.
> John
> On Apr 1, 2011, at 11:51 AM, Michael Wilde wrote:
> > Basically as far as I understand: the presence or absence of a
> > particular data file within the inout dataset is to be used to
> > determine whether the code to process that dataset subsection gets
> > invoked or not:
> >  if (exists("extra.data")) {
> >     DataFile extraInput<"extra.data">;
> >     extraResult = analyze(extraInput);
> > The above is my assumption based on a phone call. We can and should
> > verify the assumption with a simple example.
> > I also thought we can try this today by seeing if extraInput can be
> > an array, mapped to zero items if nothing to do and 1 item if
> > something to do. That would at least let us test the use case.
> > John, can you verify if the example Swift lines above are what you
> > are looking for here?
> > - Mike
> >> On Fri, 2011-04-01 at 10:51 -0500, Michael Wilde wrote:
> >>> - we should first verify that exists() will solve the NCAR need in
> >>> a
> >>> sufficiently clean way
> >> I think this is important. Can we get a description of the problem
> >> instead of a (otherwise) random proposal for a solution?
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
Michael Wilde
