[Swift-devel] Swift usage summary
David Kelly dk0966 at cs.ship.edu
Fri Sep 24 18:44:38 CDT 2010
IP addresses, return codes and anonymized user id's are among the data
currently being collected. So far there have been 51 unique users from 35
different IP addresses. The only way to get this data right now is by
manually connecting to the database. I will work on adding more of this
information to the weekly email script.
Right now all of the usage statistics are gathered outside of swift in a
shell script, so it is somewhat limited. I am working on a way to get this
integrated directly into swift, which should allow for more detail.
David
On Fri, Sep 24, 2010 at 6:56 PM, Ian Foster <foster at anl.gov> wrote:
> David:
> This looks great.
> It would be good to have some information about the location where the
> script was invoked from (e.g., IP address) so we can analyze number of
> unique users.
> Information about number of nodes, tasks, data transfers, etc., would be
> neat too. Failure information can be interesting too.
> Ian.
> On Sep 24, 2010, at 2:49 PM, David Kelly wrote:
> It is the total number of times the Swift shell script was invoked by those
> who have a recent version of Swift from trunk and have not disabled usage
> tracking.
> Right now it does not track CPU hours. The closest thing would be the real
> start and stop time for each invocation. If you find that useful, I could
> add a graph which shows the total amount of real time it uses per day.
> David
> On Fri, Sep 24, 2010 at 3:07 PM, Ioan Raicu <iraicu at cs.uchicago.edu>wrote:
>>  What are the numbers? Is it the times Swift was invoked? Or the number of
>> jobs Swift generated? Can you also plot the number of CPU hours used?
>> Ioan
>> Ioan Raicu, Ph.D.
>> Assistant Professor
>> Computer Science Department
>> Illinois Institute of Technology
>> 10 W. 31st Street
>> Stuart Building, Room 237D
>> Chicago, IL 60616
>> Cel:    1-847-722-0876
>> Office: 1-312-567-5704
>> Email:  iraicu at cs.iit.edu
>> Web:    http://www.cs.iit.edu/~iraicu/
>> On 9/24/2010 2:01 PM, dk0966 at cs.ship.edu wrote:
>> Swift usage summary attached.
>> Swift-devel mailing listSwift-devel at ci.uchicago.eduhttp://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100924/dfec6427/attachment.html>
