[Swift-devel] Re: Problems with file and sfs stagingMethods
wilde at mcs.anl.gov wilde at mcs.anl.gov
Fri Sep 24 09:18:14 CDT 2010
I'd be surprised if the sfs method works as-is, as the code in worker.pl seemed insufficient to me, but its certainly possible Ive misunderstood how its supposed to work.
Its possible that in both cases, the formats of the file names that are passing through the code differ in your test case from my test case, possibly due to our sites.xml settings
Im happy to help debug with you interactively if you have trouble reproducing the problem.
I'll later try to reproduce the problem with a clean unmodified build.
Mike
----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> On Thu, 2010-09-23 at 17:54 -0600, wilde at mcs.anl.gov wrote:
> > Or, if your tests are working, please point me to your config files,
> script, and swift revision.
> My tests do work. But regardless, the fact that some otherwise normal
> configuration, can cause problems like that needs fixin'.
> Mihael
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
