[Swift-devel] Items needed for Grid/OSG Condor-G support
Michael Wilde wilde at mcs.anl.gov
Thu Sep 2 08:55:52 CDT 2010
Glen, following up on these:
----- "Glen Hocky" <hockyg at gmail.com> wrote:
> oh but two things for the devels that we discussed before
> 1) if you could get someone to make restarting slightly easier (i.e.
> you don't have to specify all options to restart, see earlier email to
> list host)
I can do that in a swiftrun wrapper, right?
> 2) tagging the jobs submitted or at least making sure they get pulled
> out when a job fails or is canceled with the condor provider
I was going to put a "run #" tag on all condor-g jobs from a run, and create a script that removes all the jobs from a run (swiftrm) using the right condor_rm patter matching spell.
Sound OK?
- Mike
> On Sun, Aug 29, 2010 at 9:08 PM, Glen Hocky < hockyg at gmail.com >
> wrote:
> well 2 sites that would be productive, *vcell* and *mit* (forget exact
> names) both have jobs failing with "failed to transfer wrapper log"
> errors but since it works on so many other sites, i think that must be
> a problem on those sites...if we could work around or get that fixed
> that would add a lot of machines. otherwise i'm just gonna try to get
> some productive runs done (almost done one) so we can say that we used
> OSG productively....
> On Sun, Aug 29, 2010 at 8:40 PM, Michael Wilde < wilde at mcs.anl.gov >
> wrote:
> Very good, thanks Glen.
> What's the next prio on this workflow? Still some sites that are not
> building or running correctly?
> - Mike
> ----- "Glen Hocky" < hockyg at gmail.com > wrote:
> > it works now. thanks a lot
> > On Fri, Aug 27, 2010 at 2:52 PM, Glen Hocky < hockyg at gmail.com >
> > wrote:
> > ok i'll try again
> > On Fri, Aug 27, 2010 at 2:49 PM, Michael Wilde < wilde at mcs.anl.gov >
> > wrote:
> > Updated; ~wilde/swift/rev/trunk is now at: swift-r3571 cog-r2868
> > - Mike
> > > Let me know when you update...
> > > Begin forwarded message:
> > > From: Mihael Hategan < hategan at mcs.anl.gov >
> > > Date: August 27, 2010 2:01:56 PM EDT
> > > To: Glen Hocky < hockyg at gmail.com >
> > > Cc: Mike Wilde < wilde at mcs.anl.gov >
> > > Subject: Re: [Swift-user] Re: Errors in 13-site OSG run: lazy
> error
> > > question
> > > swift trunk r3568
