[Swift-devel] Re: Memory in Swift
    Jonathan Monette
    jon.monette at gmail.com
    Mon Oct 18 20:22:50 CDT 2010
  Ok.  That seemed to fix my out of memory problem.
On 10/18/2010 05:14 PM, Justin M Wozniak wrote:
> Actually, to set SWIFT_HEAP_MAX for Swift you should export it in the
> environment in which you run bin/swift .  So, in the shell you could do:
> SWIFT_HEAP_MAX=8192M swift ...
> The namespace env is there to let you set the environment for the
> remote user job.
> On Mon, 18 Oct 2010, Jonathan Monette wrote:
>> jonmon   22946 54.6  1.2 788800 318496 pts/17  Sl+  16:42   0:39 java
>> -Xmx256M
>> I am assuming that this means the heap space is 256 Megabytes.  Here
>> is how I set the SWIFT_HEAP_MAX variable:
>> <profile key="SWIFT_HEAP_MAX" namespace="env">8192M</profile>
>> Is this how you would set environment variables in the sites.xml
>> file?  I want to make sure the variable is also set for the worker
>> nodes.
>> On 10/18/2010 04:36 PM, Justin M Wozniak wrote:
>>> What do you get if you set it to 8192M?
>>>> I am on PADS.
>>>>>>    1) What is the maximum value for SWIFT_HEAP_MAX?  Is it the
>>>>>> maximum memory available on the machine?  If I ask for 8Gb will
>>>>>> the Java heap space be 8Gb?
>>>>> In bin/swift, that value is passed directly to the Java VM, so
>>>>> it's implementation-specific.  What kind of machine are you on?
>>>>>>    2) Assuming that the above question does not fix my problem,
>>>>>> what can be done to fix memory problems in Swift?  How should a
>>>>>> Swift script be programmed to avoid these issues or is how Swift
>>>>>> handles memory not optimal. I have a set of about 4100 images
>>>>>> that will be stitched together to form a mosaic.  The size of
>>>>>> this set is 8.1Gb.  Right now in my sites file I set
>>>>>> SWIFT_HEAP_MAX to 4096M(4Gb) but I am still getting out of memory
>>>>>> errors with the Java heap space.  Is Swift just not able to scale
>>>>>> up to this size of data yet?
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
