[Swift-devel] swift versions
    Sarah Kenny
    skenny at uchicago.edu
    Thu Oct 14 12:28:10 CDT 2010
so for new changes to the doc (which will eventually go into release 1.1) i
will add them to trunk. am i understanding this correctly in that i should
add a copy of the current doc dir (/ci/www/projects/swift/guides) to
trunk/docs (https://trac.ci.uchicago.edu/swift/browser/trunk/docs) & then
commit my own changes to that?
~sk
On Thu, Oct 7, 2010 at 5:05 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Thu, 2010-10-07 at 15:26 -0600, Michael Wilde wrote:
> > ----- "Justin M Wozniak" <wozniak at mcs.anl.gov> wrote:
> > > Yes, but I think that 1.0 is a release candidate- right?  New material
> > > will go into trunk until we branch for 1.1 .
> > Justin, can you clarify this?  I think we want to take most or all of
> > whats in the trunk *now*, and branch that for 1.0.  That has not been
> > done yet, has it?
> It has. For a long time. We have not yet released branches/1.0.
> > If not, lets discuss when to make the branch, and especially how to test.
> > If its already been done, lets make sure we have all we want/need from
> trunk in the release branch.
> > I'm eager to see a 1.0 very soon.
> > - Mike
> > > On Thu, 7 Oct 2010, Sarah Kenny wrote:
> > > > sounds good.
> > > > just want to verify (sorry to beat this to death):
> > > > so, we alias the 'main guide' to 0.9 (as suggested) and any changes
> > > we make
> > > > will go to the doc in branches/1.0 which will then be the new alias
> > > for the
> > > > 'main guide' once we do the release.
> > > > On Thu, Oct 7, 2010 at 3:45 PM, Justin M Wozniak
> > > <wozniak at mcs.anl.gov>wrote:
> > > >> Yup.
> > > >> On Thu, 7 Oct 2010, Mihael Hategan wrote:
> > > >>  To summarize:
> > > >>> There is a 1-1 mapping between branches and docs. One of the
> > > branches
> > > >>> (corresponding to the current release) gets linked from "main"
> > > (i.e.
> > > >>> main docs are the docs for the current release). So:
> > > >>> branches/0.9 <-> 0.9 docs
> > > >>> banches/0.8 <-> 0.8 docs
> > > >>> trunk <-> trunk docs
> > > >>> If current release is 0.9, then main docs = 0.9 docs.
> > > >>> On Thu, 2010-10-07 at 15:30 -0500, Justin M Wozniak wrote:
> > > >>>> I meant release branch.  The valid branches could be hard-coded
> > > into the
> > > >>>> update.sh script.  The main guide would be the doc associated
> > > with the
> > > >>>> current version.  So right now, "main guide" would be aliased to
> > > 0.9 .
> > > >>>>  was thinking of what justin said, "I propose we have one web
> > > site but
> > > >>>>> multiple docs/guides directories, all accessible from the
> > > docs/index.php
> > > >>>>> page.  Each of these would be associated with a branch"
> > > >>>>> i was assuming that whatever branch(es) these were associated
> > > with, that
> > > >>>>> doc
> > > >>>>> would somehow need to make its way to a main guide that we are
> > > pointing
> > > >>>>> users to.
> > > >>>>> On Thu, Oct 7, 2010 at 3:17 PM, Mihael Hategan
> > > >>>>> wrote:
> > > >>>>>  On Thu, 2010-10-07 at 14:55 -0500, Sarah Kenny wrote:
> > > >>>>>>> so, in that case the 'main user doc' would be something
> > > *like*
> > > >>>>>>> http://www.ci.uchicago.edu/swift/docs10/index.php ?
> > > >>>>>>> and THAT would include the updates from all the current
> > > branches
> > > >>>>>> define "all current branches". We have:
> > > >>>>>> 1. Release branches
> > > >>>>>> 2. Trunk
> > > >>>>>> 3. Development branches (which are transient entities and only
> > > there to
> > > >>>>>> make trunk's life easier).
> > > >>>>>>   merged into it once we do a release?
> > > >>>>>>> On Thu, Oct 7, 2010 at 2:42 PM, Mihael Hategan
> > > >>>>>>> wrote:
> > > >>>>>>>        On Thu, 2010-10-07 at 14:39 -0500, Sarah Kenny wrote:
> > > >>>>>>>     > so, in this scenario, the changes to the doc that exist
> > > in
> > > >>>>>>>        each branch
> > > >>>>>>>     > are pushed to the main user doc when we do the release
> > > or am
> > > >>>>>>>        i missing
> > > >>>>>>>     > a step here?
> > > >>>>>>>        That or we really have no "main doc" and instead we
> > > link from
> > > >>>>>>>        every
> > > >>>>>>>        release. Though I feel odd about that.
> > > >>>>>>>     > On Thu, Oct 7, 2010 at 2:34 PM, Mihael Hategan
> > > >>>>>>>     > wrote:
> > > >>>>>>>     >         On Thu, 2010-10-07 at 14:28 -0500, Justin M
> > > Wozniak
> > > >>>>>>>     >      >> On Thu, Oct 7, 2010 at 1:08 PM, Mihael Hategan
> > > >>>>>>>     >      >>> Right. I think 1.0/4.1.7 should go out soon.
> > > >>>>>>>     >      >> ok, so i guess we should decide what 'soon'
> > > >>>>>>>        means ;) i am
> > > >>>>>>>     >         currently going
> > > >>>>>>>     >      >> thru the old bugs in bugzilla (at least trying
> > > >>>>>>>        to close
> > > >>>>>>>     >         out things that have
> > > >>>>>>>     >      >> been already fixed or are no-longer applicable,
> > > >>>>>>>        etc), but
> > > >>>>>>>     >         perhaps it would
> > > >>>>>>>     >      >> be good to determine if there are bigger issues
> > > >>>>>>>        outside of
> > > >>>>>>>     >         that that still
> > > >>>>>>>     >      >> need to be dealt with before we can put what
> > > >>>>>>>        we've got
> > > >>>>>>>     >         into a stable release
> > > >>>>>>>     >      >> and determine a time-frame...anything come to
> > > >>>>>>>        mind?
> > > >>>>>>>     >      >> as far as documentation...does it make sense
> > > for
> > > >>>>>>>        each
> > > >>>>>>>     >         branch to have a full
> > > >>>>>>>     >      >> copy of /ci/www/projects/swift under it which
> > > >>>>>>>        can then be
> > > >>>>>>>     >         merged with the
> > > >>>>>>>     >      >> main/live copy whenever the code is merged?
> > > >>>>>>>        admittedly, i
> > > >>>>>>>     >         know nothing about
> > > >>>>>>>     >      >> docbook, but from the standpoint of updating
> > > and
> > > >>>>>>>        merging
> > > >>>>>>>     >         this seems to make
> > > >>>>>>>     >      >> sense to me (though feel free to suggest
> > > another
> > > >>>>>>>        way :)
> > > >>>>>>>     >      >> ~sk
> > > >>>>>>>     >      > I was looking at the update.sh script earlier
> > > >>>>>>>        today- I
> > > >>>>>>>     >         propose we have one
> > > >>>>>>>     >      > web site but multiple docs/guides directories,
> > > all
> > > >>>>>>>     >         accessible from the
> > > >>>>>>>     >      > docs/index.php page.  Each of these would be
> > > >>>>>>>        associated with
> > > >>>>>>>     >         a branch.
> > > >>>>>>>     >      > So, similar to the existing "Historical" section
> > > >>>>>>>        but for
> > > >>>>>>>     >         "future" branches
> > > >>>>>>>     >      > as well.  That would take a small modification
> > > to
> > > >>>>>>>        the
> > > >>>>>>>     >         update.sh script and
> > > >>>>>>>     >      > manual modification of the docs/index.php page
> > > for
> > > >>>>>>>        each
> > > >>>>>>>     >         version number.
> > > >>>>>>>     >      > We may also want to have the feature changes
> > > (past
> > > >>>>>>>        and
> > > >>>>>>>     >         future version
> > > >>>>>>>     >      > numbers) available on that page but I think
> > > those
> > > >>>>>>>        can be
> > > >>>>>>>     >         plain text.
> > > >>>>>>>     >      > These could be pulled directly from SVN as well.
> > > >>>>>>>     >         I agree. I generally believe that documentation
> > > >>>>>>>        should be kept
> > > >>>>>>>     >         in sync
> > > >>>>>>>     >         with releases (and I also think that the effort
> > > of
> > > >>>>>>>        doing so is
> > > >>>>>>>     >         minimal).
> > > >> Justin M Wozniak
> > > Justin M Wozniak
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20101014/8784140d/attachment.html>
