[Swift-devel] swift versions
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Thu Oct  7 11:04:18 CDT 2010
On Tue, 5 Oct 2010, Mihael Hategan wrote:
> On Tue, 2010-10-05 at 19:40 -0500, Sarah Kenny wrote:
>> ok, just want to make sure i fully understand the state of the code:
>> these are the most current/stable versions of swift & cog (that which
>> we tell users to download):
>> swift: branch/1.0
>> (https://trac.ci.uchicago.edu/swift/browser/branches/1.0)
>> cog: branches/4.1.7
>> (http://cogkit.svn.sourceforge.net/viewvc/cogkit/branches/4.1.7/)
>> these are the development (less stable) versions of the code that we
>> should be committing changes to:
>> swift: trunk/ (https://trac.ci.uchicago.edu/swift/browser/trunk)
>> cog: trunk/current
>> (http://cogkit.svn.sourceforge.net/viewvc/cogkit/trunk/current/)
>> assuming that's correct...
>> for swift, what are the other/multiple directories under branches/
>> that do not appear to be releases or release candidates?
>> is the intent, upon the next swift release (whenever that may be) to
>> update swift branch/1.0 with the changes that have been committed to
>> trunk/ ?
> Right. There are two reasons for doing branches:
> 1. if some work divergent from trunk is needed
> 2. to stabilize for a release
> For (1), if thinks work out OK, you eventually merge them back into
> trunk.
> (2)s also get merged back into trunk in one way or another, since they
> may contain bug fixes.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
So for Swift 1.1, can we have a CoG 4.1.8?
Justin M Wozniak
